X20Xev Starting Trouble
upk
Yesterday my manta with its x20xev conversion would not restart after initially running and starting ok. Today after some reading on the net I first off cleaned the ICV and confirmed solenoid was operating ok. After refitting car started instantly on first turn and ran ok. Now it will not start again.
I have a spark
I have fuel on fuel rail but not sure if it's enough pressure although it did run earlier. I have tried my old crank sensor back on. Now I am scratching my head so any enlightenment will be welcome.
Edited by upk
The two most common causes of failure to run or start is the cam shaft and crankshaft sensor. I'm assuming you're running standard injection.
The next I have encountered is an intermittent switched live connection to the coil.
After that it could be anything.
Yes it's all standard. It dud fire up again this afternoon and ran for a good 10 mins with no problem but I cannot get it to restart.
Drained out all the fuel from the tank and put in a fresh can full. Purged through lines but hey oh no difference.
Guess I need to get a new cam and crank sensor and see if that sorts it. At times like these don't you wish you had another known good engine to swap bits out of!
http://www.autovaux.co.uk/product-cat/electrical/sensor-camshaft.aspx
http://www.autovaux.co.uk/product-cat/electrical/sensor-crankshaft.aspx
If you have the old style camshaft sensor they really do cause issues. Go for the new type. It comes with a section of loom to splice into your existing one.
But to save wasting money do the paperclip test and find out what the fault codes are.
http://www.topbuzz.co.uk/
Thanks snowy.
Unfortunately I can't do paper clip test as I did not wire in the ALDL port. I have spent the evening with my head in my wiring diagrams and think I have worked out how to put one in. Actually don't need to wire full port which helps as I don't have one!
I reckon if I wire in the engine management warning light ( live feed to lamp then connect other side to ecu pin 52 and also to pin 2 of the imobiliser )and short pin 22 of the ECU to ground via a switch it's as good as?
Honestly looking at pin out for the ALDL there is not much more I think I need to worry about.
Before doing all this I will just check I am not loosing the switched live to the coil / immobiliser etc. could have a dodgy connection from the rebuild.
I have a spark
Had a mk3 cav with this engine. The ICV sometimes needed a couple of cleans for it to work consistently. I did replace most of the sensors along the way too but this valve was the cause most of the time. Great engine when running right though! Edited by Dan W
Based on the the fact it started first time after I had cleaned the IAC valve I decided to replace this as first off.......still no good it won't start. Over this weekend I have wired up the malfunction indicator lamp and carried out the blink count test. This is what I get in flash out order:-
P1690- check light voltage low
P0505- IACV voltage low
P0110- intake air temp voltage low
P0135- O2 sensor heating voltage low
P0340- camshaft sensor incorrect signal
P1502- imobiliser no signal
P1503- immobiliser wrong signal
I have checked continuity from every sensor on the engine back to the ecu connector. Battery was fully charged and been disconnected from car 24hrs before test, but I am concerned about the low voltage faults!! I have reconfirmed all wiring for the imobiliser and confirmed when key is not present mil light flashes repeatedly and is on constantly when key is next to transponder.
Unless there is any more advice out there on this one I am going to replace camshaft sensor next as recommended by snowy and hopefully is the problem and causing other faults. I suspect immobiliser is an old fault from the rebuild as I did go ignition on once without transponder plugged in and I believe old faults do not reset unless done so by the use of appropriate device.
Flash codesWhen the cam sensor and crank sensor disagree the engines run terribly. Disconnect the cam sensor and it runs perfectly with 4500RPM limit. Seeing as you have to disconnect before removing.............
Not true, the later engines will not run at all.
And to prove the point I disconnected the cam sensor on my calibra and it does not start!
97 X20XEV in my 96 Vectra ran fine barring the imposed 4500 RPM limit and was better than the misfiring when they were disagreeing. Same situation in wife's 97 Vectra, same engine. Both on Siemens ECU. They don't run without crank sensor. They go into limp with cam because they probably have to batch fire injectors from not knowing which 2 cylinders are are TDC at same time.
IIRC Calibras stopped being made in 97 so about the same age. We'll have to beg to differ
Either way he should be able to get flash codes to help diagnose.
From the codes above immobiliser is likely. A lot of "voltage low" too so maybe a good charge and check battery terminals and earths.
