Shug Posted April 19, 2015 Share Posted April 19, 2015 Oops, forgot all about it. PM me your address sutty. Link to comment Share on other sites More sharing options...
guysat Posted April 25, 2015 Share Posted April 25, 2015 Hi there. The 2.2 ecu is bosch part number 0280000326.cant see how this would work correctly with a standard 2 litre loom thou because the 2.2 has additional items over a 2 litre. Namely an idle speed control valve which maintains an ideal idle speed controlled by its own control box.0280220017 for a manual and 0280220018 for an auto.it also doesnt have the 2 litres 5th injector/cold start on the end of the inlet manifold.also the ignition system uses a different module and a different distributor. The advance is not centrifugal but controlled by yet another box 02277921015 manual or 0227921006 auto.maybee and i dont know because i have the correct full set up on mine a 2.2 will work perfectly ok with a 2 litre system. Someone will no doubt have tried this and will hopefully be able to advise?? Hi, some very useful part No's there Im currently using 0280220018 on a manual setup do you know the differences between the 20017 and 20018 Is my injection being compromised for using the Auto part ? Link to comment Share on other sites More sharing options...
cam.in.head Posted April 29, 2015 Share Posted April 29, 2015 Hi. The difference is that the auto unit holds the idle at 700 rpm whereas the manual should be 800 .so cant see any real issues there Link to comment Share on other sites More sharing options...
Shug Posted May 11, 2015 Share Posted May 11, 2015 Did you get the relay Sutty? Posted it a week or so ago so should have arrived. 1 Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 11, 2015 Author Share Posted May 11, 2015 Yeah it arrived thanks shug I atuck it straight on the loom and forgot about it lol. Cheers Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 17, 2015 Author Share Posted May 17, 2015 Sump pick up pipe and engine mounts now sourced. Just waiting on gearbox remote linkage. Link to comment Share on other sites More sharing options...
