Novasportc550 Posted September 23, 2015 Share Posted September 23, 2015 having a small issue with my fuel pump, it works fine, but gets noisy if the car is sitting ticking over after about 30 seconds, but if you drive, it's fine.. It sounds like it's backing up the pressure or something..! I am running a c20xe on throttle body's with a fuel pressure valve at the end of the rail.. The fuel pump is at the back of the car on the under side. The pump is a standard one you would put in a Sri cavalier etc. I am on my 3rd pump and all 3 have done the same.. The power supply to the pump is just switched threw the ignition and is not on a relay. Not sure if that would effect it.. Anyone else have this problem..!! thanks.. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted September 23, 2015 Share Posted September 23, 2015 Fit a radio, turn it up full! Ac/Dc works best! Are you running a carb tank or a injection tank, What fuel setup are you using! Same as manta originally, 1 Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 24, 2015 Author Share Posted September 24, 2015 Running a injection tank. The fuel pump is just a standard cavalier Sri one.. It's not a manta one .. Quote Link to comment Share on other sites More sharing options...
eldoradoCoupe Posted September 24, 2015 Share Posted September 24, 2015 Did you clean the pipe coming out of the tank attached to the fuel sender - could be gunked up on the inside restricting the flow to the pump, or muck coming out of it blocking the little wire gauze in the pump.. Seeing your resto you probably already been there but just a thought. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted September 24, 2015 Share Posted September 24, 2015 (edited) Cav pump is ok, but have you used all of the above bw photo setup in that order, arrangement? Edited September 24, 2015 by brady Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 24, 2015 Author Share Posted September 24, 2015 If if there was a restriction on the fuel coming into the pump surely my engine would have fuel starvation up the revs, but she revs perfect up the revs eldoradocoupe.. my set up is just the pump and the filter brady. What's the other parts in the manta set up..!! Quote Link to comment Share on other sites More sharing options...
eldoradoCoupe Posted September 25, 2015 Share Posted September 25, 2015 Just re-read actually, if it happens after sitting at idle - it sounds more likely a restriction in the return line. Other part is the damper, never run without it myself but I've read many others on here say it doesn't make a difference. Quote Link to comment Share on other sites More sharing options...
madmantamik Posted September 30, 2015 Share Posted September 30, 2015 had the same problem on a monza, turned out to be the filter. Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted September 30, 2015 Author Share Posted September 30, 2015 Got this wee problem sorted today guys, ended up being the fuel pressure valve was stuck shut, not allowing the fuel to return to the tank.. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted September 30, 2015 Share Posted September 30, 2015 (edited) good to know! noted for future cure! Did you renew the diaphram? if so, where did you get it? Edited September 30, 2015 by brady Quote Link to comment Share on other sites More sharing options...
Novasportc550 Posted October 1, 2015 Author Share Posted October 1, 2015 Had another one, so just changed it.. Quote Link to comment Share on other sites More sharing options...
