Berlinetta Posted December 11, 2015 Share Posted December 11, 2015 I recently took delivery of an orginal Opel 'dealer option' Fog Lamp Set for my Manta B (thanks to 'Scribe of Lincoln'!). The only part I now require is the Electrical Relay for the fog lamps. Anybody here got a spare? ...or would a generic relay suffice? I'd also be interested in a set of plastic covers for the (round) fog lamps ...if anybody has a set to spare? Link to comment Share on other sites More sharing options...
Snowy Posted December 11, 2015 Share Posted December 11, 2015 From memory the fog lamp relays are fused. But the pin out varies from the standard relay layout in the fuse box. But it is very easy to swap terminals over in the fuse box. Link to comment Share on other sites More sharing options...
stradacab Posted December 13, 2015 Share Posted December 13, 2015 I don't think the relays are fused, they are a standard relay and it goes into the vacant slot at the far end of the bottom of the fusebox nearest the a post. in your wiring loom you will find the flyleads on the brace between the front chassis legs (in front of the rad) there will either be some spare plugs with the headlamp and headlamp wash wipe wiring or tw wires with plain ends either side. One green, one black. Black is for fogs, green is auxiliary driving lamps. basically if you fit the switch, bang in the really and wire the lights I think you should be good to go Link to comment Share on other sites More sharing options...
Exclusive Opel Posted December 13, 2015 Share Posted December 13, 2015 (edited) Have a look at my post here:(may need to click on 'front fog lights') Edited December 13, 2015 by Exclusive Opel Link to comment Share on other sites More sharing options...
Snowy Posted December 13, 2015 Share Posted December 13, 2015 I don't think the relays are fused, they are a standard relay and it goes into the vacant slot at the far end of the bottom of the fusebox nearest the a post. in your wiring loom you will find the flyleads on the brace between the front chassis legs (in front of the rad) there will either be some spare plugs with the headlamp and headlamp wash wipe wiring or tw wires with plain ends either side. One green, one black. Black is for fogs, green is auxiliary driving lamps. basically if you fit the switch, bang in the really and wire the lights I think you should be good to go The for lamp relays should have a fuse built into them. The originals had the standard fuse fitted. But you can still but fused relays. These do plug into the standard fuse box underneath. Problem is you can use a standard relay but then you have no fuse protecting the circuit. If you look at this ebay auction you can see the fused relay I'm talking about. http://www.ebay.co.uk/itm/Opel-Manta-GTE-Berlinetta-Cavalier-etc-job-lot-interior-trim-switches-relays-/272073382359?fits=Car+Make%3AOpel|Model%3AManta+B+CC&hash=item3f58d659d7:g:PcMAAOSw~OdVVKIE http://www.vehicle-wiring-products.eu/product.php/643/12v-4-blade-fused-relay Link to comment Share on other sites More sharing options...
stradacab Posted December 13, 2015 Share Posted December 13, 2015 Ah now I didn't know that. I though the feed for it came from the fused side of the fuse rail. I will have to check because the Ascona and GT-J both have unfused relays fitted Link to comment Share on other sites More sharing options...
