biffy1984 Posted April 18, 2016 Share Posted April 18, 2016 What's the best mounts to use? I seem to remember something about using 1 original 1800 rubber and maybe a Capri one?? Sure this has been discussed many times before but thought it would be easier to start a new topic rather than trawling through old topics for hours looking for an answer. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Paul 84 Posted April 18, 2016 Share Posted April 18, 2016 Rally design sell them and retro power there 50mm thick like a big bobbin with a m10 stud either side I used two one each side and my xe is steady as a rock Quote Link to comment Share on other sites More sharing options...
vauxhallkeith Posted April 18, 2016 Share Posted April 18, 2016 Yeah a used the 1s from retro power. Ma engine is solid aswel. Think there bowt 20bucks fea retro power. Quote Link to comment Share on other sites More sharing options...
biffy1984 Posted April 18, 2016 Author Share Posted April 18, 2016 So both 50mm? I'm asking cause mine has at the moment a bigger mount on the drivers side for some reason. Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted April 18, 2016 Share Posted April 18, 2016 EM672 pearl parts do them if still available. 50 mm with m10 studs Quote Link to comment Share on other sites More sharing options...
biffy1984 Posted April 18, 2016 Author Share Posted April 18, 2016 Perfect, thanks Quote Link to comment Share on other sites More sharing options...
vauxhallkeith Posted April 18, 2016 Share Posted April 18, 2016 Yeah both 50mm mate Quote Link to comment Share on other sites More sharing options...
mantasrme Posted April 18, 2016 Share Posted April 18, 2016 I just use the one 50mm on the passenger side and an original round one on the drivers side. Due to the rotational motion inside the engine quickly coming off the clutch lifts the engine on the passenger side and can rip the mount apart if you are really aggressive/ its old and tired. But the drivers side is under compression so as long as you swap the V shaped original mount for a Round version its not going to break. With both sides changed to the 50mm version you get a lot more engine vibration into the car. 1 Quote Link to comment Share on other sites More sharing options...
