shooie811 Posted April 26, 2016 Share Posted April 26, 2016 Hi anybody selling a ready to go front bolt on brake upgrade anything at all ? Cheers chris Link to comment Share on other sites More sharing options...
Snowy Posted April 27, 2016 Share Posted April 27, 2016 What are you limitations, such as wheel size? Link to comment Share on other sites More sharing options...
shooie811 Posted April 27, 2016 Author Share Posted April 27, 2016 Ive got 15s on it ive just converted the rear to mk4 astra calipers and discs and went to bleed it and the front bleed screws snapped plus they are proper ancient so just looking for a upgrade on them Link to comment Share on other sites More sharing options...
robah Posted April 27, 2016 Share Posted April 27, 2016 I know mantasrme (David) use to do the upgrade front brake kits. Astra GTE 52/24 calipers with Audi 80 vented discs, if he hasn't got any he might be able to point you in the right direction. Link to comment Share on other sites More sharing options...
wayne ingham Posted April 27, 2016 Share Posted April 27, 2016 Have a look at Corsa Calipers ( 2/12/15) you will see photos of the brake mod that l carried out.The brakes are 100% better Link to comment Share on other sites More sharing options...
mantasrme Posted April 28, 2016 Share Posted April 28, 2016 I will have a look and see what i have in stock. How big a brake setup do you want, or how much power are you running/how do you drive. I normally say the 256mm Astra/Audi setup to start with then if you want more braking power the Calibra turbo calipers and cosworth 284mm discs (which require rear discs to balance out right) Link to comment Share on other sites More sharing options...
shooie811 Posted May 4, 2016 Author Share Posted May 4, 2016 On 28 April 2016 at 11:16 PM, mantasrme said: I will have a look and see what i have in stock. How big a brake setup do you want, or how much power are you running/how do you drive. I normally say the 256mm Astra/Audi setup to start with then if you want more braking power the Calibra turbo calipers and cosworth 284mm discs (which require rear discs to balance out right) Im still running the cih i have already converted the rear to mk4 astra discs and want to upgrade the fronts as they are the original ones 40 year old now and there just cutting the mustard just looking for a nice easy upgrade cheers chris Link to comment Share on other sites More sharing options...
