Engine earth strap location- Manta
dog321fish
Something is telling me gearbox area,  an xtra long stud, to engine block, a bolt with another tread to loop strap on then secure with nut, then it goes to inner swan neck!
If you have a swanneck :ph34r:
Edited by ®evo03
fingers too big
Not sure on location on 1.8 but they should have a strap from the engine to chassis (not 100% on location without looking)
The OMOC Microfiche shows 2 different lengths, one at 210mm GM 08932204, and one at 310mm GM 11060242, which I think is down to engine type, is the 1.8 engine block thinner?
Yes, you're correct - one from the gearbox to the swan neck and one from the engine block,  below the exhaust manifold to the cross member bolt that comes through the chassis leg on the passenger side inner wing.
