A series fuel tank bafflling
johnboy
Had a baffle put in an A tank about a year ago, and works fine with inj. engine.
It was done by my local radiator shop, Warwick Radiators, they cut a slot in the top half of the tank, just to the side of the sender unit. and then slotted in a baffle plate, and welded all in place. A return pipe was also fitted so the returning fuel went into the new chamber.
You can use a GTE coupe tank as suggested but you do louse quite a bit of boot space.
This is probably not how most people would do it but its how i did mine :-)
http://www.theopelproject.com/?p=47
http://www.theopelproject.com/?p=45
http://www.theopelproject.com/?p=534
Im sure you could probably find a shorter in-tank until so it was just the height of the tank and have it not sitting out the top and still get the tank strapped under the floor.
Andy
