IanMc Posted July 9, 2019 Share Posted July 9, 2019 Hi all, Has anyone devised a fix for the mounting/locating pins on the side Louvre vents. The drivers side one on my Cav Coupe only has two pins doing anything. I had previously tried super gluing them, but they broke again as soon as I fitted it. Thanks in advance for any money saving help you can provide 👍 Quote Link to comment Share on other sites More sharing options...
H-400 Posted July 9, 2019 Share Posted July 9, 2019 Hi Ian, had the same problem. Used Building gleu Tec7, had problems to to get them off again. Not sure you can buy the same mark in the UK but if you google it you can find the base what that gleu is made of and look for a local replacement. 1 Quote Link to comment Share on other sites More sharing options...
IanMc Posted July 10, 2019 Author Share Posted July 10, 2019 Thanks Herman, really appreciate your help - I will see if I can find it over here Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 10, 2019 Share Posted July 10, 2019 (edited) How about araldite or something similar (epoxy resin) stuck my land rover end cap lugs back on worked a treat I believe there are epoxys specifically for plastics on eBay.if they have snapped off flush bend a couple of small cut down nails at 90 degrees and build a wider footing this is what I done. Edited July 10, 2019 by hoobby Footing 1 Quote Link to comment Share on other sites More sharing options...
IanMc Posted July 10, 2019 Author Share Posted July 10, 2019 Cheer Graeme, much appreciated. ps whens the big day (MOT)? Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 10, 2019 Share Posted July 10, 2019 Soon..ish just got to sort all the electrical probs I'm now aiming for July 19th if the car will allow it and doesn't have a tantrum.yours looks very nearly ready? And very nice too.good luck with the fix. 1 Quote Link to comment Share on other sites More sharing options...
