Clamps/brackets
Chris M
Hi All, hope you are all well.
Does anyone know where you can get the brackets/clamps for the pre fuel filter/pump/main fuel filter under a GTE coupe.
I have discovered the small section of pipe between the pre filter and pump is leaking and I would like to take the opportunity to remove the pre filter and give it a good clean out while I am at it. They are expensive little buggers to buy new I have found but I reckon the brackets holding them on could probably do with replacement while I am under there.
Thanks
1 hour ago, Jessopia74 said:
I found the ore-filter on eBay , but it’s a bit expensive, never found the bracket though
oops forgot the eBay number 🤦🏻‍♂️
253318648665
Yes I found them also. Almost £50 posted from Germany and £67 for alloy ones over here .  I read on here recently you can wash them out as it’s a coarse mesh filter inside to stop larger chunks of debris getting inside the fuel pump. I will give the parts microfiche CD a go.  Got plenty of time on my hands unless someone comes along and points me in the right direction.
Cheers
The pre-filter is indeed expensive, found it also in Germany. Those clamps that are used on the pre-filter and fine-filter are common parts in the car industry. We use them also
to guide looms and airpressure lines of trucks, maybe a truck-workshop can help you?
Think he means the whole bracket Herman.
The other ones are multi industry parts, called ‘ P clip’
Edited by Jessopia74
