BEEDZ Posted July 17, 2020 Share Posted July 17, 2020 Got a gte engine with fuel injection But it’s marked 2.0S there’s no plate fitted for fuel pump I thought the 2.0E was injection and the 2.0S was carb Any ideas Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted July 17, 2020 Share Posted July 17, 2020 Probably a recon at some time in its life. I have one that was a factory recon and it has 2.0s on the block. 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 17, 2020 Share Posted July 17, 2020 Pretty much the same anyway. Maybe you have a bit of a larger capacity engine if it’s had a remote and oversize pistons 😁 1 Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 17, 2020 Share Posted July 17, 2020 3 hours ago, BEEDZ said: Got a gte engine with fuel injection But it’s marked 2.0S there’s no plate fitted for fuel pump I thought the 2.0E was injection and the 2.0S was carb Any ideas There is no difference in the blocks so as said probably a GTE spec built into a S block. What kind of lifters does it have? 1 Quote Link to comment Share on other sites More sharing options...
BEEDZ Posted July 17, 2020 Author Share Posted July 17, 2020 2 hours ago, Snowy said: There is no difference in the blocks so as said probably a GTE spec built into a S block. What kind of lifters does it have? thanks Snowy I was led to believe it had come out as an original engine with 64000 miles on if that makes sense Thanks again Quote Link to comment Share on other sites More sharing options...
Snowy Posted July 17, 2020 Share Posted July 17, 2020 3 hours ago, BEEDZ said: thanks Snowy I was led to believe it had come out as an original engine with 64000 miles on if that makes sense Thanks again It can't be original as the factory wouldn't have built a GTE with a 20S block. But it still could be original as the supplying dealer may have done this as a warranty claim on the engine. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 17, 2020 Share Posted July 17, 2020 as they say above ,all should be well providing the head is a P2E head (dep on year) physically blocks are the same ,timing cover different as you have seen. 1 Quote Link to comment Share on other sites More sharing options...
