DeeBob Posted August 3, 2020 Share Posted August 3, 2020 Hello all, The hard brake lines that run from the master cylinder to the smaller cylinder on the passenger side of my car are in need of replacement, does anyone know if a kit for these exists from someone like Automec or will I need to make some up? Cheers, Quote Link to comment Share on other sites More sharing options...
H-400 Posted August 3, 2020 Share Posted August 3, 2020 I get them at our local car parts shop and they fit the right threathed connections and flare the lines. Just need to know how long the line is but bending them can be tricky. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 3, 2020 Share Posted August 3, 2020 Make up. Some shops do a bit more if a professional job bending to match the original profile so ask about the local suppliers, but should not be expensive if you got a garage to do it. Quote Link to comment Share on other sites More sharing options...
1200bandit Posted August 3, 2020 Share Posted August 3, 2020 If you secure (tape) one end to the old pipes then bend the new pipe the same as the old one and tape it on the bend , you will find it quite easy to do 1 Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted August 3, 2020 Share Posted August 3, 2020 There are a few tools out there for making smaller bends...and straightening coiled pipe... Quote Link to comment Share on other sites More sharing options...
