execman Posted September 18, 2020 Share Posted September 18, 2020 hi, I have no red fuel pressue light on my dashboard; I know it used to work but has now stopped, since work started gettting the car back on the road after around 5 years parked in my garage. the guage itself works fine; what can be the problem anyone? Quote Link to comment Share on other sites More sharing options...
BIG STU Posted September 18, 2020 Share Posted September 18, 2020 Try a new bulb👍 1 Quote Link to comment Share on other sites More sharing options...
hoobby Posted September 18, 2020 Share Posted September 18, 2020 If you disconnect this block and give both terminals an earth the oil light should come on and needle drop to zero if so then it would be the connection on the oil sender is corroded or the sender is bad If not then it's the bulb. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 18, 2020 Share Posted September 18, 2020 correct Quote Link to comment Share on other sites More sharing options...
