front chassis rails
stumpy
ime sorted for everything is but are they available from the swan neck forward ?? or is anyone fabbing them i dont mind makin themmyself if need be but fr quickness ide  buy  a pair if theyre about      and while ime here can you get coil overs to fit/or adaptable to fit  a manta
Edited by stumpy
Thats just the shape they are, cant imagine them being any other shape, seen them made from box section before.
They rust because of the hole at the top! Look at the passangers side top plate, just below battery tray, all the water of the roof, windscreen, is directed to the battery tray, out the drain and down this hole, between the inner and outer skin. Both legs have these holes.
I always use a grommet found in the door pin to block these holes.
