Mickfrad Posted May 26, 2021 Share Posted May 26, 2021 As the title says what is it and a what does it do ? My headlights started coming on when I braked, getting brighter the harder I pressed then fading out gradually. After checking all the earth’s I remembered this box tucked up in the passenger footwell. Unplugging it has sorted my problem and everything appears to be working ok. So what have I lost and should I just bin it and save a little weight ? Quote Link to comment Share on other sites More sharing options...
Danny D114BCW Posted May 26, 2021 Share Posted May 26, 2021 Bin it, save the weight. It is for hot countries where the headlights have to be on during the day. This stops them/wiring overheating apparently. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted May 26, 2021 Share Posted May 26, 2021 Think it also drops the voltage should you leave your lights on. Who leaves their lights on? So if it drops your voltage, the battery will be dead in 8 hours opposed to 4? Seems you have fixed your fix. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 26, 2021 Share Posted May 26, 2021 Yup dim dip relay. Send it into the scrap bin. Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted May 26, 2021 Author Share Posted May 26, 2021 Will leave it disconnected then, my headlights used to have a faint glow when sidelights were on so that was probably due to this then. Never liked the look of that. The part number brings some up on eBay, not sure it’s a buzzer though. https://www.ebay.co.uk/itm/VAUXHALL-NOVA-Astra-HEADLIGHT-RELAY-WARNING-BUZZER-TRANSFORMER-GM-90274651-/233859230516?_trksid=p2349624.m46890.l49286 Quote Link to comment Share on other sites More sharing options...
