Snowy Posted July 18, 2021 Share Posted July 18, 2021 Anyone got a 1600 CIH crankshaft for sale? I will take a short motor or complete engine? Thanks Link to comment Share on other sites More sharing options...
®evo03 Posted July 18, 2021 Share Posted July 18, 2021 Whats the preference for a 1.6 crank? Just interested. Link to comment Share on other sites More sharing options...
Snowy Posted July 18, 2021 Author Share Posted July 18, 2021 18 minutes ago, ®evo03 said: Whats the preference for a 1.6 crank? Just interested. A better crank for tuning compared to the 2L item. 1 Link to comment Share on other sites More sharing options...
®evo03 Posted July 18, 2021 Share Posted July 18, 2021 How? Why, and it what way? Seen plenty dumped, is the 19 same as 2.0s / e. Link to comment Share on other sites More sharing options...
Snowy Posted July 19, 2021 Author Share Posted July 19, 2021 11 hours ago, ®evo03 said: How? Why, and it what way? Seen plenty dumped, is the 19 same as 2.0s / e. Different counter weights so revs better, especially at higher rpm. 1 Link to comment Share on other sites More sharing options...
®evo03 Posted July 19, 2021 Share Posted July 19, 2021 Reason i asked was i have a manta b 1.6, before i restored it, it came with poly windows, bucket seats and harness, bit weird i thought! Then thought maybe it had a xe in, saab turbo, but all was original, when it came to strip down, no body mods, no butchering, very original undamaged car, and never damaged or repaired. I think there is something done to the engine but cant figure out why someone would modify a cih 1.6, and its the original block, maybe its had head work, bigger valves etc, it is quick, had it at 115, which is weird for a 1.6, 4sp, original axle. Such a weird wee car, tdi vw racer! Running original solex carb. Must check my engine bank for 1.6 blocks. Link to comment Share on other sites More sharing options...
Snowy Posted July 20, 2021 Author Share Posted July 20, 2021 13 hours ago, ®evo03 said: Reason i asked was i have a manta b 1.6, before i restored it, it came with poly windows, bucket seats and harness, bit weird i thought! Then thought maybe it had a xe in, saab turbo, but all was original, when it came to strip down, no body mods, no butchering, very original undamaged car, and never damaged or repaired. I think there is something done to the engine but cant figure out why someone would modify a cih 1.6, and its the original block, maybe its had head work, bigger valves etc, it is quick, had it at 115, which is weird for a 1.6, 4sp, original axle. Such a weird wee car, tdi vw racer! Running original solex carb. Must check my engine bank for 1.6 blocks. Don't forget you can bore the 1600 to 1900 so it may have been bored out. 1 Link to comment Share on other sites More sharing options...
rutts Posted July 25, 2021 Share Posted July 25, 2021 Got a 1.6 crank here been balanced up for high rpm. No bearing shells. 1 Link to comment Share on other sites More sharing options...
