Which coil
JeffShaw
just make sure you get the one designed for constant 12v (bosch kw12v)and not the earlier coil used with points.this coil only runs at 6-9v and will soon burn itself out if fitted to a electronic injection car which yours is.
to check. measure the resistance across the 2 outer terminals.which should be less than 1.0 ohm.( 0.6-0.9)
NOT 1.2-1.6 ohm .(early points coil)
  • Like 3
