moodoo Posted July 8, 2022 Share Posted July 8, 2022 Cool...makes sense...thanks for the explanation... (Sorry for the mini thread hijack...!) 1 Quote Link to comment Share on other sites More sharing options...
ANDY ABBOTT Posted July 10, 2022 Author Share Posted July 10, 2022 On 06/07/2022 at 09:09, Moonmonkey said: It’s a lot easier to do with the engine out, I’ve never done it with the engine in situ but i can’t see why it couldn’t be done. It’s just more awkward to set up and see the timing marks/protractor. The biggest issue is finding an accurate measure of TDC with the cylinder head on. You could work it out from the ignition timing marks, and some engines have a ball bearing and a pointer on the flywheel. You could strip off some ancillaries and take the radiator out to make it easier to work on. I would be happy to come over and help you do it, I’m just getting over Covid but should be ok in a few days😊 I may just have to take you up on that 😆 On 07/07/2022 at 16:15, Jessopia74 said: yeah, it’s hard to find a guide that would not introduce more confusion unless you have done the task before. But fair play for some having a go to help others out. The Cam Andy has should be on solid followers anyway (if not then that’s an issue in itse, but yeah it’s worth a point that they should be swapped 👍 We fitted brand new solid lifters along with the new kent op254 cam Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 10, 2022 Share Posted July 10, 2022 3 hours ago, ANDY ABBOTT said: I may just have to take you up on that 😆 We fitted brand new solid lifters along with the new kent op254 cam That’s good, expected you would but as it’s turned out to be a topic for general info on how to, it’s worth noting 👍 I will just reiterate the point about setting an accurate TDC. Do not rely on any markings currently on engine, make a pointer from a welding rod etc. when you fix the wheel to the crank / crank pulley, and use the DTI gauge down the spark plug, you can get an accurate reading on the CIH this way, but I do agree on some engines it’s not possible. 1 1 Quote Link to comment Share on other sites More sharing options...
