etxee Posted July 7, 2023 Share Posted July 7, 2023 Hi So this will be my first post. I tried the search in the forum but I only found issues regarding vibrations which increased with speed. My car starts vibrating at 15mph and stops completely at about 30mph. It is a bit of a strange thing....then at around 70mph you get another sort of vibration, which I will tackle at a later stage. But for the meantime I would appreciate any for the big vibration, which by the way there is no need of gear engagement or even engine running! Many thanks in advance Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 7, 2023 Share Posted July 7, 2023 Sounds like prop UJ then to me Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 7, 2023 Share Posted July 7, 2023 Or prop phasing is out. Have you had the propshaft out recently? Eliminate the cheap stuff first - get wheels and tyres balanced, check your tracking and a visual inspection of all the bushes, ball joints and track rod ends. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted July 8, 2023 Share Posted July 8, 2023 As above. Check your tyres aren’t out of shape or have a huge bulge in. Then head for prop after that. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 8, 2023 Share Posted July 8, 2023 so to be clear.... if you get up to above 15 mph and either turn the engine off or drop the clutch the vibration is still there ? has any recent work been done regarding removing propshaft,gearbox ,brakes or wheels/tyres ? loose nuts ? the fact that it dissapears after 30 is weird, are the brakes all free to turn ,discs or drums not distorted ? or as mentioned any tyre irregularities ? Quote Link to comment Share on other sites More sharing options...
etxee Posted July 12, 2023 Author Share Posted July 12, 2023 Thank u all.... It was the prop shaft Ujoints..the 4 nuts in the rear side of the shaft were quite lose, even though they have the retaining washer... Furthermore, the whole part was slightly offset to one side, hence the vibration. After a bit of tightening all 4 shaft bolts, replacing the engine (in this case gearbox) mount which was broken and replacing the spring at the gearbox end that pushes the shaft longitudinally to the rear.... the vibration was gone. There are still minor vibrations which still have to be traced... Not sure whether to look in the bearings or bushings.... 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted July 12, 2023 Share Posted July 12, 2023 1 hour ago, etxee said: Thank u all.... It was the prop shaft Ujoints..the 4 nuts in the rear side of the shaft were quite lose, even though they have the retaining washer... Furthermore, the whole part was slightly offset to one side, hence the vibration. After a bit of tightening all 4 shaft bolts, replacing the engine (in this case gearbox) mount which was broken and replacing the spring at the gearbox end that pushes the shaft longitudinally to the rear.... the vibration was gone. There are still minor vibrations which still have to be traced... Not sure whether to look in the bearings or bushings.... Glad you caught it before it failed 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 13, 2023 Share Posted July 13, 2023 yes thats good news. if the prop is very loose (or wrongly fitted originally) the rear cups can sit tilted on the flange rather than snugly between the two raised lugs. this would causea bad vibration without doubt. Quote Link to comment Share on other sites More sharing options...
