RetroRob Posted August 14, 2023 Share Posted August 14, 2023 After letting my gte sit yet again for nearly a year , it's got some electric faults, not all the time when I press the brakes the side lights come on and the hazard lights don't work just glows on the dash when I put the hazards on , any ideas would be appreciated..cheers Rob Quote Link to comment Share on other sites More sharing options...
chrisb Posted August 14, 2023 Share Posted August 14, 2023 Sidelights when braking is the dim/dip relay in the passenger side footwell behind the kick panel, just unplug that and bin it, That will cure that, common problem on the exclusive 2 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted August 14, 2023 Share Posted August 14, 2023 Had similar issue after rebuilding something, remember it was the rear lights earth's affecting the headlights. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 14, 2023 Share Posted August 14, 2023 yes earth connections can affect many other items in strange ways. if you have a bad earth on anything the electric will find its best path of lowest resistance back to earth.if that happens to be through other bulbs it will make them glow. same reason that a bad engine earth strap will melt a clutch cable ! for the static hazard light i would just check the cleanliness of the fuses. the holders are not particularly strong and the 2 dissimilar metals create corrosion eventually.worth popping a new set in every few years. also try repeatedly operating the hazard switch. they often only get used once a year for the mot so can get dirty inside . 1 Quote Link to comment Share on other sites More sharing options...
RetroRob Posted August 14, 2023 Author Share Posted August 14, 2023 Cheers guys 👍 Quote Link to comment Share on other sites More sharing options...
RetroRob Posted August 15, 2023 Author Share Posted August 15, 2023 20 hours ago, cam.in.head said: yes earth connections can affect many other items in strange ways. if you have a bad earth on anything the electric will find its best path of lowest resistance back to earth.if that happens to be through other bulbs it will make them glow. same reason that a bad engine earth strap will melt a clutch cable ! for the static hazard light i would just check the cleanliness of the fuses. the holders are not particularly strong and the 2 dissimilar metals create corrosion eventually.worth popping a new set in every few years. also try repeatedly operating the hazard switch. they often only get used once a year for the mot so can get dirty inside . Just put a new set of fuses in and all working fine now ..cheers 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 15, 2023 Share Posted August 15, 2023 youre welcome . 1 Quote Link to comment Share on other sites More sharing options...
