Greg w Posted December 31, 2023 Share Posted December 31, 2023 I’m refitting my front and rear screens, do they need any sealer around the glass or where the rubber seal sits in the body aperture? i don’t want to if not necessary but i presume clear silicone would do if its needed Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted December 31, 2023 Share Posted December 31, 2023 Do not use silicone. I don’t have any on my A series but that have in the B. you need none setting, I just run a small bead once fitted on outer lip Quote Link to comment Share on other sites More sharing options...
611 Posted December 31, 2023 Share Posted December 31, 2023 As Paul said. No need to add any around where the rubber goes onto the screen but i would add some round the outside outer lip after installing. It might be fine without out but if not it will probably be a while before you realise its leaking and then its hard to trace where its coming in. I found mine leaked in the bottom corners on front and back before and this time after painting the car i made sure i sealed all around after fitting both screen just to be on the safe side. Don't use silicon, use this: https://midlandsealants.com/product/arbomast-autograde/ Andy Quote Link to comment Share on other sites More sharing options...
Greg w Posted January 1 Author Share Posted January 1 yes that’s similar to what i’ve put around all the side window trims. i’ve still got a tube. thanks, just curious why not silicone as i remember back in the day that is what was sold as windscreen leak stop for this kind of seal. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 1 Share Posted January 1 (edited) I don't know what silicone would be used for nowadays. As above non setting windscreen sealer. As the window and seal move and eventually settles, non setting allows for that. And allows for window to be removed. And cleaned, I've sealant remover😉 There are loads of types of sealant, from car body work, tigerseal, brushable bodysealant, non setting sealant. Household sealants, worktops, windows, basins, sinks, etc. If you are looking sealant, try typing what you are using it for, eg. Windscreen sealant The traditional silicone, would be classed as a quick fix nowadays. I never use it, as it dries and normally only lasts a few months if lucky. Horrible stuff. Edited January 1 by ®evo03 Quote Link to comment Share on other sites More sharing options...
611 Posted January 1 Share Posted January 1 3 hours ago, Greg w said: yes that’s similar to what i’ve put around all the side window trims. i’ve still got a tube. thanks, just curious why not silicone as i remember back in the day that is what was sold as windscreen leak stop for this kind of seal. The silicon would stick nicely but im nut sure over time how it would cope with the movement as @evo03 said. The non setting stuff will work much better with movement from hot and cold etc.. Its a bit like sealer they use on roofing that is non setting so it can flex with the movement and not lift and leet water under. And some cheap silicon is not that flexible. Quote Link to comment Share on other sites More sharing options...
