Rear Axle Ratios and Vauxhall FE
ukartist
3 hours ago, cam.in.head said:
yes that picture does show a difference . i wonder what the difference is made by ?
always learning stuff that how we become who we are and thankyou for taking the time and effort
It would be interesting to know what it’s made by, because I recon it isn’t much, so maybe different stub casting on the half shaft? I’ve been looking out for a spare rear anyway but they aren’t around now.
Looking at the parts book the axle casing is the same part number, the difference being the half shafts and associated hardware like bearings & retainers
cheers for the info.
and thankyou also for mr sutty for bringing it up and my apologies for not noticing it myself. my gm parts book doesn't mention it but the haynes sure does ! right at the beggining of the book it says the track widths and sure enough the estate is virtually same front and rear but the saloon is less ??
never seen it written there !
the bearing should be the same and it's retained by the backplate so it sounds like the difference must be in the thickness or offset of the actual wheel surface mounting flange /area.( similar idea to fitting a wheel spacer in principle)
wonder why on earth they thought a saloon needed to be less track width than an estate ? why not just make them both the same wider spec
Edited by cam.in.head
Probably designed the saloon width first. Then fitted the saloon axle to an estate and thought “damn, we need this wider!”
I was told it’s wider because of the extra weight it can carry, the wider track made it more stable round corners. Could be completely wrong but it’s a viable explanation.
quite possibly yes.
the saloon and estate both have the same front track at 1435mm
the saloon rear is 1412mm
the estate rear is 1432mm
so a 1cm difference each side ( and even that is less than the front !)
haynes book page 6 !
  • Like 3
