Carb to air box adapter plate?
Sutty2006
Got a 32/36 Weber on my engine but am I missing an adapter plate for the air box?
I have another air box with a round hole, so there could be two different ones?
thanks
Just checked an old filter pan I have Steve, it’s the same as yours with a rectangular aperture. Like Ian I think I have an adaptor off a weber 32/36 but if I recall, the fitting is for an oval aperture. I’ll dig it out and check.
I also have a round filter pan, but not oval.
failing that, I’ll get a filter that bolts to the top of it. But I’m unsure what to do with the vacuum advance pipe or the rocker box breather pipe.
Just been in my shed and sorry can’t find the adapter plate was sure I had one this has reminded me I really need to sort out stuff though!
I had a bid on this.
I might probably be out bid though. But it looks like my vacuum advance plugs into the bottom of the carb, so I can vent the rocker cover to atmosphere.
@rutts let me know if you find owt 👍
3 hours ago, Metalbasher said:
I’ve dug this out Steve, it’s the adaptor from a weber 32/36 but to an oval aperture filter pan
I recon that would fit, but I don’t think I have anything that would fit on top.. the other pan filter box I have has a mounting bolt through the middle.
