twin head light lamps
huw
peter lloyd rallying in bridgend mid glam got em in stock,not a million miles from where you are,he does mail order as well,they are the cibie valeo repacements inner and outers i bought a set of 4 off him for my exc coupe not messin about drillin holes just fit em and away to go
  • 5 weeks later...
on all the cars i have had the holes lined up with the long bolts,if not should be easy enough to drill a couple off holes to suit.
you will notice when you remove you old headlight
infact i just put a set on my hatch and the bolts were in the corners and fitted ,straight on :thumbup
  • 3 months later...
Try this for the lights (I use the Saturnus units in mine) which are a lot cheaper than others.
I must have posted this link at least a dozen times - but oh well!!
http://www.holden.co.uk/displayproducts.as...+%2D+5+3%2F4%22
and for mounting rings - these come complete with adjusters etc. You may have to re-drill the twin unit case to fit but its simple. (mine are ok).
http://www.demon-tweeks.co.uk/products/Pro...code=CIB9999810
Good luck with whichever way you go,
