youthofbritain Posted August 22, 2009 Share Posted August 22, 2009 Im after, most importantly, a sump pan so i can make my c20xe a rear wheel drive, and also i need an A series prop shaft so that my rear wheels will drive!!! A complete handbrake cable wouldn't go a miss either. Any help much appreciated. James Link to comment Share on other sites More sharing options...
Rick-Manta Posted August 23, 2009 Share Posted August 23, 2009 I'd need an A series boff to advise on this, I have a 1.9SR propshaft from a B but given the change in length by using a Getrag 5 speed it maybe the right length?? Link to comment Share on other sites More sharing options...
Robbie Posted August 23, 2009 Share Posted August 23, 2009 You will need a B series prop and then when your engine is in etc, you will need it shortened to length, handbrake cables are not that easy come by, there are 2 types so you need to check which one you have , ball end or hook. you can always change the rear shoes though if you come across either cable. Link to comment Share on other sites More sharing options...
youthofbritain Posted August 24, 2009 Author Share Posted August 24, 2009 before we go any further......it may be a good idea to paint a better picture. I've got an opel kadett coupe which this engine is going in to. I have a manta a series axle and tube on the back and a getrag 5 speed manta box to go on the engine. Now are you saying that its a manta B prop i need to fit? I've also just been notified that there is a company called Reco Prop online that will make me a prop from scratch to the spec you want. Any one heard if there good or no? Cheers for the help Link to comment Share on other sites More sharing options...
simon p Posted August 24, 2009 Share Posted August 24, 2009 before we go any further......it may be a good idea to paint a better picture. I've got an opel kadett coupe which this engine is going in to. I have a manta a series axle and tube on the back and a getrag 5 speed manta box to go on the engine. Now are you saying that its a manta B prop i need to fit? I've also just been notified that there is a company called Reco Prop online that will make me a prop from scratch to the spec you want. Any one heard if there good or no? Cheers for the help recoprop are awesome, i use them all the time. Link to comment Share on other sites More sharing options...
Paul Barrett Posted September 3, 2009 Share Posted September 3, 2009 ive got a b series prop from a 2.0 gte sat here its not much use to me now, (also a big wing sump on ebay atmo) Link to comment Share on other sites More sharing options...
