mantacrazy22 Posted October 24, 2009 Share Posted October 24, 2009 hi im in desperate need of a rear fog light unit and mounting bracket in working order for mot re test.many thanks if you can help matt Link to comment Share on other sites More sharing options...
alan Posted October 24, 2009 Share Posted October 24, 2009 Hi matt can borrow mine if you want mate. Wont need it till feb time hopefully.give us a bell mate 07786632307. At work today but could pick it up tom if you want Link to comment Share on other sites More sharing options...
mantacrazy22 Posted October 24, 2009 Author Share Posted October 24, 2009 Hi matt can borrow mine if you want mate. Wont need it till feb time hopefully.give us a bell mate 07786632307. At work today but could pick it up tom if you want hi alan thats great very good of you,need it for early next week so thats spot on ill give you a bell tommorow and pop through if its ok thanks alot mate matt Link to comment Share on other sites More sharing options...
Rab Posted October 24, 2009 Share Posted October 24, 2009 If required, have brand new item all to add bulb and use existing wiring £20 inc postage if wanted. cheers rab. Link to comment Share on other sites More sharing options...
mantacrazy22 Posted November 2, 2009 Author Share Posted November 2, 2009 If required, have brand new item all to add bulb and use existing wiring £20 inc postage if wanted. cheers rab. thanks rab all sorted now borrowed alans for mot.cheers matt Link to comment Share on other sites More sharing options...
Ped Posted November 25, 2009 Share Posted November 25, 2009 thanks rab all sorted now borrowed alans for mot.cheers matt If you still need a fog lamp I have a good second hand one, with mounting bracket. Bulb not tested, but was working 11 years ago when it was removed. See pic below. No idea how much its worth, so make me an offer. 07788550370 Cheers Link to comment Share on other sites More sharing options...
Ped Posted November 27, 2009 Share Posted November 27, 2009 If you still need a fog lamp I have a good second hand one, with mounting bracket. Bulb not tested, but was working 11 years ago when it was removed. See pic below. No idea how much its worth, so make me an offer. 07788550370 Cheers Its now on ebay. Link to comment Share on other sites More sharing options...
®evo03 Posted November 30, 2009 Share Posted November 30, 2009 (edited) Just an idea! , ive fitted these to both mantas, bought a bulb holder and bulb, comes with two wires, one is earth, I removed the driverside rear light, and drilled into the reflector from back of housing! , its the section between brake light, and reverse lense, Earth on wire, connect the other You now have a fog light, that doesnt fill with water, doesnt get smashed on high kerbs, and most important, doesnt look like, "SHIT" we forgot the fog light!! HAD MOT recently, "ok, try your fog light, oh, its too old to have one!! my reply>, TOO OLD..... of course it has one! , when did they think fog was invented!! Ive fitted mine to drivers side only, but could be fitted to both sides, to balance it out! this does not change the appearance of the rear lenses! 10 minutes fits it!, good bright light too! I can get these complete with bulb holder, bulb, wire, instructions! £12 plus postage! < it tidies up any rear end!!! Edited November 30, 2009 by brady Link to comment Share on other sites More sharing options...
vauxsenb Posted November 30, 2009 Share Posted November 30, 2009 Any chance of a pic from the inside of the boot to demonstrate what your describing, cant quite picture how that would work but would be very interested in doing it on my hatch. Many thanks, Colin. Link to comment Share on other sites More sharing options...
rutts Posted November 30, 2009 Share Posted November 30, 2009 same idea but put the foglight wire to the drivers side reverse light, put a red 12 LED bulb in and its bright enough for mot and looks standard but as said no dangling fog light under the bumper. Link to comment Share on other sites More sharing options...
vauxsenb Posted November 30, 2009 Share Posted November 30, 2009 same idea but put the foglight wire to the drivers side reverse light, put a red 12 LED bulb in and its bright enough for mot and looks standard but as said no dangling fog light under the bumper. Tried that but wasn't happy with the result and it was a struggle to get the LED bulb into the body of the lamp so still wearing the dangly version at the mo' cheers, Colin. Link to comment Share on other sites More sharing options...
mantadoc Posted November 30, 2009 Share Posted November 30, 2009 A lot of fuss about a fog light found on many 80s and 90s Vauxhall / Opels such as Astra MKII / Kadett E The only bit different is the bracket which is usually what is left if you break one or easily made. Link to comment Share on other sites More sharing options...
