BlackTurbo73 Posted October 4, 2010 Share Posted October 4, 2010 Hi again all,still same old problem as my c20 let manta has a stand alone Mitsi evo ECU no body will tune it for me. i have fitted a boost gauge and its showing 5psi???????? Which seems odd as the car is seriously fast but there. Does anyone know what PSi boost a C20 let is optimal and safe at? Quote Link to comment Share on other sites More sharing options...
Shuviteer Posted October 4, 2010 Share Posted October 4, 2010 you'll be fine with 1.5 bar. Some folks go 2+ bar, but thats when you'll find out any problems in the system.Make sure your fuel pump can handle it and injectors handle flow. Quote Link to comment Share on other sites More sharing options...
BlackTurbo73 Posted October 4, 2010 Author Share Posted October 4, 2010 1.5 bar in psi? I have saab red injectors which apparently are good? Quote Link to comment Share on other sites More sharing options...
upk Posted October 4, 2010 Share Posted October 4, 2010 1 bar=14.7 psi so work it out from there! Quote Link to comment Share on other sites More sharing options...
BlackTurbo73 Posted October 4, 2010 Author Share Posted October 4, 2010 Great thanks for that,know anyone in norfolk area who knows what they are doing adjusting the boost? Quote Link to comment Share on other sites More sharing options...
Christ Posted October 4, 2010 Share Posted October 4, 2010 Not norfolk but just round the corner.... http://www.corten-miller.co.uk/ very knowledgeable guys, might be able to set it all up for you 5psi sounds very low, where have you plumbed your boost gauge into? Quote Link to comment Share on other sites More sharing options...
andyc Posted October 5, 2010 Share Posted October 5, 2010 If your having problems with getting the ECU sorted you could always go for an Emerald setup from dave Walker in Watton. The ECUs are made with a base map which Dave Walker then sets up on his rolling road. I know its spending more money but at least you know it will be correct and won't have to worry about blowing up the motor Just an idea Andy Quote Link to comment Share on other sites More sharing options...
simon p Posted October 5, 2010 Share Posted October 5, 2010 (edited) Hi Marc, when i fitted the engine for the former owner, i used the stock ECU, have you still got that? if so, it may be worth refitting it and get rid of the EVO ECU currently on there. Another idea is to maybe contact the people the former owner asked to do all the tuning work if they're still trading to see if they can help you. Edited October 5, 2010 by simon p Quote Link to comment Share on other sites More sharing options...
BlackTurbo73 Posted October 5, 2010 Author Share Posted October 5, 2010 Thansk for the replies,managed to get hold of the other guy who tinkered with the car and its a V-max evo 5 chip in the std ECU which is good news so hopefully i can just move forward from there. The engine had a brand new block and was skimmed,new pistons,bottom end rebuild and timing belt all about 18months ago and has done nothing since so seems i have a good base to work on. i am planning to check for leaks 1st as 5 psi does seem too low and then get running about 14psi and should be able to eat most things around off the line. Only problem is the manta becomes very light on the back at speed (over 100mph) and to be honest im very nervous driving at that. I guess this is a common issue? Quote Link to comment Share on other sites More sharing options...
Retro Power Posted October 15, 2010 Share Posted October 15, 2010 On our kadett c turbo we were running 22 psi on a standard bottom end, with XE cams (inlet and exhaust) and it was making 400hp To be honest, the engine is the least problem if you have a standard back axle. On the lightter kadett we smashed the manta axle repeatedley (on every trip to santa pod, fortunately I had plenty of them) it usually broke the diff carrier, but later sheared the prop off and smashed the torque tube too, plus it ate an 1800 manta gearbox most times out too! The car is now running different running gear, including a v6 omega gearbox, which WAS bulletproof for 2 years, but last month broke after running an 11.3sec 1/4 mile, at 26psi boost ond a little over 500hp. It stripped all the teeth off 3rd gear, bent the mainshaft and pushed the layshaft bearings clean though the casing........... Just to fill you in on what can happen when you keep wanting more. if you take a look on our website (link in the bottom of our posts) and look in the projects section for kadett c turbo you'll get the gist:) PS we binned the std ecu as it just can't cope, we were running it chipped (remapped a good few times) but it was very hard work, it was much cheaper in the long run to fit a programmable ecu, as its a quick (and cheap) job to sort remapping now Quote Link to comment Share on other sites More sharing options...
