Roy Posted December 2, 2010 Share Posted December 2, 2010 Hi can anyone help with a Bosch part number for the alternator fitted as standard to a 1.9 1977 'B auto ? My local motorfactor is willing to help me source a more powerful upgrade for it but he wants the original part number. Unfortunately its worn off the label on mine. Can anyone help? thanks Roy Quote Link to comment Share on other sites More sharing options...
Exclusive Opel Posted December 2, 2010 Share Posted December 2, 2010 These are the numbers I have for a 45A alternator as fitted to Mk1 Cavalier between 1975-1981: No guarantee of accuracy but maybe it's a start. Augros 2 29 34 62/4 Autostart A462 Autostart A574 Bosch 0 120 400 620 Bosch 0 120 400 681 Bosch 0 120 400 840 Bosch 0 120 400 841 Bosch 0 120 489 108 Bosch 0 120 489 109 Bosch 0 120 489 629 Bosch 0 120 489 630 Bosch 0 986 030 180 Bosch 0 986 030 330 Bosch 0 986 030 810 Bosch 0 986 030 811 Bosch 0 986 030 820 Bosch 0 986 030 821 Delco Remy 031-15 Delco Remy 031-99 Delco Remy 031-150 Delco Remy 3472002 Delco Remy 3472028 Delco Remy 3472057 Delco Remy DRA0810 Delphi 3472028 Doyen DAL30810 EDR 930810 Electrostart AN26 Electrostart AN225 Farcom 118035 Friesen 90 30810 GEAI 55802 GEAI 55806 GKN 3011 GKN 3065 GMC 12 04 111 GMC 12 04 128 GMC 12 04 160 GMC 12 04 161 GMC 12 04 167 GMC 12 04 169 GMC 12 04 311 Hella 8EL 725 566-001 Holger Christiansen CA110IR Lucas 23992 Lucas 66021099 Lucas LRA00110 Lucas LRA110 Lucas LRA00860 Lucas LRA860 Magneti Marelli 943356527 Magneti Marelli 943356744 Magneti Marelli 943356527010 Magneti Marelli MAR490 Magneti Marelli MAR491 Opel 1204017 Opel 1204111 Opel 1204161 Opel 1204167 Opel 1204169 Opel 1204311 PSH CV 135002045 QX Components Limited QA0211 Sovereign SA462 Sovereign SA969 UBD 13065 Unipart GXE2019 Unipart GXE2033 Unipart GXE2340 Valeo 9AR2618K Valeo 436154 Valeo 436155 XL X930810 The Bosch site lists it as 0 120 489 630 {K1®14V 20/45A} but NLA They list the above number for both 45A and 55A versions. They also list the alternatives as: 0 986 030 830 or 0 120 489 111 Quote Link to comment Share on other sites More sharing options...
g_gjikas Posted December 2, 2010 Share Posted December 2, 2010 Roy,the Bosch number you need is 0120489108.It is the standard 45A alternator fitted in your car. I am currently searching for a bigger one for my exclusive,if you need another code let me know. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted December 3, 2010 Share Posted December 3, 2010 1982-1986 senator 2.5 have a 65amp bosch version that still uses the normal aluminium mount.i beleive higher models use 80 odd amp one which will fit but you need the larger cast mount & a different `threaded` adjustment bar.also of course the car will take a larger battery than the standard 063 size. up to a 071 or dep on make a 075 size. Quote Link to comment Share on other sites More sharing options...
Julian Posted December 3, 2010 Share Posted December 3, 2010 Roy,the Bosch number you need is 0120489108.It is the standard 45A alternator fitted in your car. I am currently searching for a bigger one for my exclusive,if you need another code let me know. That's the same number that's fitted on my 1977 1.9 Cav also, and according to the previous owner it is OE. Quote Link to comment Share on other sites More sharing options...
Roy Posted December 4, 2010 Author Share Posted December 4, 2010 Great thanks guys, give me plenty to go back with I'll go as big as I can get Amp wise then I won't have to worry about using fans, electric screen heaters, lights etc through the winter. Couldn't believe the price of decent size batteries now Quote Link to comment Share on other sites More sharing options...
Julian Posted December 4, 2010 Share Posted December 4, 2010 Great thanks guys, give me plenty to go back with I'll go as big as I can get Amp wise then I won't have to worry about using fans, electric screen heaters, lights etc through the winter. Couldn't believe the price of decent size batteries now Have you checked the price at your Vauxhall dealer? Don't forget to take your little yellow card with you Quote Link to comment Share on other sites More sharing options...
g_gjikas Posted December 9, 2010 Share Posted December 9, 2010 1982-1986 senator 2.5 have a 65amp bosch version that still uses the normal aluminium mount.i beleive higher models use 80 odd amp one which will fit but you need the larger cast mount & a different `threaded` adjustment bar.also of course the car will take a larger battery than the standard 063 size. up to a 071 or dep on make a 075 size. Do you know the number code for that 65amp alternator?Because I am in search of buying a new one and your help can be major.Thanks Quote Link to comment Share on other sites More sharing options...
Julian Posted December 9, 2010 Share Posted December 9, 2010 (edited) Do you know the number code for that 65amp alternator?Because I am in search of buying a new one and your help can be major.Thanks The part number for the 65amp is 0120489112, which is no longer available, but a recon is available, and the part number for that is 0986041600, at a cost of £180.00 trade, retail price I do not know. so if you go looking for an used one it should have the first number stamped on it. ie 0120489112. That info has come from my son, who works for Bosch. Hope it is of some help to you. Edited December 9, 2010 by Julian Quote Link to comment Share on other sites More sharing options...
g_gjikas Posted December 10, 2010 Share Posted December 10, 2010 The part number for the 65amp is 0120489112, which is no longer available, but a recon is available, and the part number for that is 0986041600, at a cost of £180.00 trade, retail price I do not know. so if you go looking for an used one it should have the first number stamped on it. ie 0120489112. That info has come from my son, who works for Bosch. Hope it is of some help to you. Julian,that was a major help from yourpart.Thanks a lot.Before your reply,I could only assume for that code.I phoned Bosch here in Greece and they told me a very expensive price for that 65A part..155 euros without VAT and 210euros with the VAT..Maybe, a good solution is to rebuild my 45A one with parts of a 65A alternator,a good electrician can do that. Quote Link to comment Share on other sites More sharing options...
Julian Posted December 10, 2010 Share Posted December 10, 2010 Julian,that was a major help from yourpart.Thanks a lot.Before your reply,I could only assume for that code.I phoned Bosch here in Greece and they told me a very expensive price for that 65A part..155 euros without VAT and 210euros with the VAT..Maybe, a good solution is to rebuild my 45A one with parts of a 65A alternator,a good electrician can do that. Glad to be of help mate, that what this club is all about Quote Link to comment Share on other sites More sharing options...
