battersby Posted April 12, 2011 Share Posted April 12, 2011 hi to everyone i have just a 19 sr reg HDD120L chassis no 599921016 can some one give me a build date i also want to change the engine for some thing more modern eg unleaded not to bothered about speed can someone advise the easiest way to go so i can start collecting parts while i am doing the body up i would also like to thank everyone in the club for a great site its so friendly and well run cheers for your help graham Quote Link to comment Share on other sites More sharing options...
Shug Posted April 12, 2011 Share Posted April 12, 2011 Thats a higher number than my chassis no which is not tax exempt. (early jan 73 ) If performance doesn't worry you, you could just have your head converted to unleaded. Quote Link to comment Share on other sites More sharing options...
battersby Posted April 12, 2011 Author Share Posted April 12, 2011 Thats a higher number than my chassis no which is not tax exempt. (early jan 73 ) If performance doesn't worry you, you could just have your head converted to unleaded. cheers shug the car was registered may 73 but it was worth a try i know i could have head converted but car isnt running yet it had been parked on a drive for 15 yrs dont exspect engine to be much good i dont mind more power but have to go for the cheapest and easiest option eg wife and 5 kids cheers again Quote Link to comment Share on other sites More sharing options...
upk Posted April 12, 2011 Share Posted April 12, 2011 good luck with the project, as always it will come down to how much budget you have available! if you search the project section you will find lots of inspiration............... kev Quote Link to comment Share on other sites More sharing options...
ray70 Posted April 12, 2011 Share Posted April 12, 2011 hi to everyone i have just a 19 sr reg HDD120L chassis no 599921016 can some one give me a build date i also want to change the engine for some thing more modern eg unleaded not to bothered about speed can someone advise the easiest way to go so i can start collecting parts while i am doing the body up i would also like to thank everyone in the club for a great site its so friendly and well run cheers for your help graham Hi Mate, There are a couple of A series engines on ebay right now here is the item number - 220767456163. Good luck Ray. Quote Link to comment Share on other sites More sharing options...
battersby Posted April 12, 2011 Author Share Posted April 12, 2011 thank you all for your advice i think i will go for the 16 crank 2.2 head kent cam 2.0 rebore so will be on the look out for parts . got a lot of body work to keep me busy new wings to go on passenger side rear arch to cut out and replace battery tray etcbut considering how long its been outside its quite solid can anyone tell me where i can get windscreen rubber as they have perished cheers again graham Quote Link to comment Share on other sites More sharing options...
Shug Posted April 12, 2011 Share Posted April 12, 2011 Windscreen rubbers are available from dr manta or ps autoteil in Germany. I got the ps autoteil ones and the fit is pretty good. Quote Link to comment Share on other sites More sharing options...
611 Posted April 12, 2011 Share Posted April 12, 2011 Hi Found this is an old club mag Chassis numbers: 592xxx made in or before 1972 lower than 599904213 made in or before Jan 1973 595xxx or 598xxx made in or after 1973 Thought it might be of some interest. Andy www.theopelproject.com Quote Link to comment Share on other sites More sharing options...
doveyte2800 Posted April 12, 2011 Share Posted April 12, 2011 Hi, Just been reading the other replies, so I thought i'd check something. Dont forget its not when it got its plates but when its built. Our car has a chassis no of 5999210.. and is tax exempt. Dont give up, i know its not an opel but i have a triumph that was plated in august 1973 but was built in november 1972! Ian Quote Link to comment Share on other sites More sharing options...
monzta Posted April 16, 2011 Share Posted April 16, 2011 You could do a 2,0 OHC 8 valve (130bhp) for the car, and later it would be easy to throw in a c20xe Quote Link to comment Share on other sites More sharing options...
