jim nolan Posted April 9, 2012 Share Posted April 9, 2012 (edited) Manta A series fuel tank question !!! can anyone tell me if the standard A series fuel tank will do for a B series gte engine upgrade ? or do i need to modify the A series tank in anyway ? ( fitting the gte engine in to A series manta ) Edited April 9, 2012 by jim nolan Quote Link to comment Share on other sites More sharing options...
mantaray Posted April 9, 2012 Share Posted April 9, 2012 you will need to sort out a fuel return, if you use a swall pot and feed the return into that then you can use the aA tank Quote Link to comment Share on other sites More sharing options...
jim nolan Posted April 9, 2012 Author Share Posted April 9, 2012 theirs two litte pipes allready sticking out of the tank ,can i use one of those for the return ? Quote Link to comment Share on other sites More sharing options...
mantaray Posted April 9, 2012 Share Posted April 9, 2012 the 2 little pipes are the breather pipes, and I don't think they will be big enough and will restrict the return to much. Quote Link to comment Share on other sites More sharing options...
Robbie Posted April 9, 2012 Share Posted April 9, 2012 (edited) A series tank is no good for your job, Just get a B series injection tank will save a lot of hassle, you will also need the fuel pump assembly from underneath a injection model ( brackets etc ) Plus the engine bulkhead plug from an injection loom as you will need to do a few wiring mods like removing and replacing the resistance coil wire with a normal type cable. Edited April 9, 2012 by Robbie Quote Link to comment Share on other sites More sharing options...
monzta Posted April 16, 2012 Share Posted April 16, 2012 A series tank is no good for your job, Just get a B series injection tank will save a lot of hassle, you will also need the fuel pump assembly from underneath a injection model ( brackets etc ) Plus the engine bulkhead plug from an injection loom as you will need to do a few wiring mods like removing and replacing the resistance coil wire with a normal type cable. WHAT ?? A B-series tank will never fit a A series car, what are you talking about. The B series tank is located behind the rear seats and the A series tank is located under the trunk floor ??? Completely different designs... Jim; you should search for a Manta A GT/E tank but they can be very hard to find. They have the fuel return pipe. If that is not possible you can get a fuel return pipe soldered onto your existing tank. Another possibility (however a bit on the expensive side) could be a trunk mounted safety tank from Motorsports.. But again, that will set you back a pretty penny. Any plummer workshop should be able to solder a fuel return for you, just remember that the tank must be completely cleaned (not just emptied) before you do anything to it. Some even fill them with water when working on them. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted April 17, 2012 Share Posted April 17, 2012 WHAT ?? A B-series tank will never fit a A series car, what are you talking about. The B series tank is located behind the rear seats and the A series tank is located under the trunk floor ??? Completely different designs... The B coupe tank fits nicely behind the rear seats with a little work making mounts and pipework from what i've seen actually. Quote Link to comment Share on other sites More sharing options...
monzta Posted April 17, 2012 Share Posted April 17, 2012 What ? What about the tube for filling up the fuel ? It is located extremly low on the A series cars and i cannot ever see how it should be possible... I would very much like to see pictures of such a mod ! Quote Link to comment Share on other sites More sharing options...
jim nolan Posted April 17, 2012 Author Share Posted April 17, 2012 sorry ,internets been crap !!!! want to keep the tank where it is and not give up any boot space . so ill go down the route of putting a return pipe on the tank ! any place in particular the return pipe should be located ? or would any where on the top lip of the tank do ? Quote Link to comment Share on other sites More sharing options...
Robbie Posted April 17, 2012 Share Posted April 17, 2012 WHAT ?? A B-series tank will never fit a A series car, what are you talking about. The B series tank is located behind the rear seats and the A series tank is located under the trunk floor ??? Completely different designs... What ? What about the tube for filling up the fuel ? It is located extremly low on the A series cars and i cannot ever see how it should be possible... I would very much like to see pictures of such a mod ! Its a very easy mod, Ive done it a few times, you leave the filler on the B series tank and fill from the boot, just like the rally cars. lol as for where the tanks fit on the A and B series, I think after 15 years of restoring and moding mantas I might have an idea where they are located Might if I get time take a pic of my V8 a series as I have the tank fitted in the boot of it beside the NOS Tank. Quote Link to comment Share on other sites More sharing options...
monzta Posted April 17, 2012 Share Posted April 17, 2012 Oh i would love to see that Robbie, i have never thought that was possible. My apologies, guess i still have stuff to learn about the Manta mods Jim Nolan: Here´s a link for you mate, you´ll need to brush of your German though or use google translate http://www.mantawelt.de/gte-tank.htm Quote Link to comment Share on other sites More sharing options...
Alf Posted April 17, 2012 Share Posted April 17, 2012 sorry ,internets been crap !!!! want to keep the tank where it is and not give up any boot space . so ill go down the route of putting a return pipe on the tank ! any place in particular the return pipe should be located ? or would any where on the top lip of the tank do ? I'm sure there are many ways of doing what you require, the way I did it when I fitted a 24v engine to my Commodore was to take the fuel sender unit out of the tank, drill a hole, fit some pipe and solder in place, that was 7 years ago and it's still running fine today, that way you remove any danger of setting yourself on fire as well!! Cheers, Alf. Quote Link to comment Share on other sites More sharing options...
611 Posted April 17, 2012 Share Posted April 17, 2012 This link will show you the difference between the standard A tank and the one used in germany for the injection A series. http://www.theopelproject.com/shop-manual/opel-manta-a-series-injection-fuel-tank.pdf (might take a little while to open as a large file) you can see from the second tank photo where the return comes in at the right hand side. and a little mod im doing to mine :-) in tank swirl pot and pump. http://www.theopelproject.com/wp-content/uploads/2011/11/011120111160.jpg Andy Quote Link to comment Share on other sites More sharing options...
jim nolan Posted April 18, 2012 Author Share Posted April 18, 2012 I'm sure there are many ways of doing what you require, the way I did it when I fitted a 24v engine to my Commodore was to take the fuel sender unit out of the tank, drill a hole, fit some pipe and solder in place, that was 7 years ago and it's still running fine today, that way you remove any danger of setting yourself on fire as well!! Cheers, Alf. brilliant ,,,thanks Alf and cheers Andy great link Quote Link to comment Share on other sites More sharing options...
