Kevin Abbott Posted October 7, 2012 Share Posted October 7, 2012 I'm making something special and require 3 more standard manta jacks. Anyone got any cheap? I gave away all my spares and now I need some! Link to comment Share on other sites More sharing options...
opelscott22 Posted October 7, 2012 Share Posted October 7, 2012 I might have one for you, Im away with work at the moment but if your still in need when Im home ill pop it in the post for you. Scott Link to comment Share on other sites More sharing options...
opelmantagsi Posted October 8, 2012 Share Posted October 8, 2012 so whats the plan? my guess is its some kind of body shell trolley / dolley... Link to comment Share on other sites More sharing options...
mantasrme Posted October 8, 2012 Share Posted October 8, 2012 I'm sure i have several lying around you can have for free Kev I'll check later how many i can find Link to comment Share on other sites More sharing options...
plumster Posted October 8, 2012 Share Posted October 8, 2012 Only got the one I lift the car up with... and Yes I still lift the car up with it Link to comment Share on other sites More sharing options...
mantasrme Posted October 9, 2012 Share Posted October 9, 2012 I've found 5 jacks so far, 3 matching with the cast/pressed handle and 2 with the bent rod handle. Which is it you were after? Link to comment Share on other sites More sharing options...
Kevin Abbott Posted October 9, 2012 Author Share Posted October 9, 2012 Cheers David. It's not the handle that's important, it's the bit that goes into the jacking point. The one I have is a solid bar welded onto the extension that sticks out of the upright. I presume that bit is all the same? I will be making some WRC stands out of them :-) Link to comment Share on other sites More sharing options...
mantasrme Posted October 10, 2012 Share Posted October 10, 2012 Both types have a solid bar but one type goes in to the arm further than the other Top is the rod handle type, bottom is the pressed type (which is actually made by Bilstein) The top is stamped as rated to 400kg, the lower to 530kg You can have all 5 if you want, i never use them. Link to comment Share on other sites More sharing options...
plumster Posted October 10, 2012 Share Posted October 10, 2012 Proper anoraks, I love you guys. Link to comment Share on other sites More sharing options...
Kevin Abbott Posted October 10, 2012 Author Share Posted October 10, 2012 It will have to be the bilstein ones then as I'm collecting the chassis numbers off them :-) Link to comment Share on other sites More sharing options...
