ascona400r Posted August 19, 2013 Share Posted August 19, 2013 Hello guys.. Need to take the gearbox out of a redtop powered Manta for a friend. It has a 1.8s gearbox fitted and was wondering if it is possible to remove and attach the gearbox whilst leaving the engine in the engine bay. Cheers Brian Quote Link to comment Share on other sites More sharing options...
mantadoc Posted August 19, 2013 Share Posted August 19, 2013 It is for the 1.8 Manta so unless head too tight to bulkhead in some way no good reason why not Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted August 24, 2013 Share Posted August 24, 2013 Personally I would support the back of the engine somehow, to take the strain off the engine mounts. A bar across the wing rails with a strap under the sump would be fine. Quote Link to comment Share on other sites More sharing options...
manta88 Posted August 24, 2013 Share Posted August 24, 2013 I tryed a few years ago and found that there was not enough room as the clutch cover plate is bigger on the XE conversion and ended up removing the engine. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted August 24, 2013 Share Posted August 24, 2013 Yes its possible to remove the gearbox, with practice you can do it quite quickly. Think Mr Rutter was down to about 1hr or so when he was changing boxes regularly when he was breaking them a lot Quote Link to comment Share on other sites More sharing options...
mickappy Posted August 24, 2013 Share Posted August 24, 2013 done this a few times on my own. no probs Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted August 25, 2013 Share Posted August 25, 2013 I've had an 1800 box off on my own on DIY garage ramps and axle stands. Had to lie on my back, gearbox on my legs..... Then on refitting used my feet on the bell housing and hands on the output flange to wiggle it back on. I should get a proper ramp shouldn't I? Haha Quote Link to comment Share on other sites More sharing options...
