Smallest Brake Servo To Fit Standard Location
CRAZYDAVE
I should have the part number for the Polo servo, will look it out.
When I looked into this the diameter was smaller but the depth was a bit more than the stock servo.
I looked into and bought a remote servo, yeah there are places it can be mounted but I ended up abandoning the idea and selling the servo
I ended up doing a brake bias pedal box in the end.
I had a look at the holden Gemini ones (Chevette)
$(KGrHqNHJF!FJGVpBZ9RBSUz)DILSQ~~60_12.J
$(KGrHqMOKowFJLbPgp8MBSUz)kQb0!~~60_12.J
They are smaller in diameter, if not depth,(?)
Could be an easy option as I am pretty sure they bolt into the same holes, have the same attachment to the manta pedal, although actuator rod length may need to be modified?,
  • 1 month later...
