mcintbg Posted September 1, 2014 Share Posted September 1, 2014 Is there a trick to removing them from my manta a ? Quote Link to comment Share on other sites More sharing options...
611 Posted September 1, 2014 Share Posted September 1, 2014 Yep, there is a small clip on the back of the winder that you need to pop off to release them. Its basically the same setup as this image. use two small flat blade screw driver and you can leaver it out. Andy Quote Link to comment Share on other sites More sharing options...
mcintbg Posted September 1, 2014 Author Share Posted September 1, 2014 do i go under the black plastic or above it ? Quote Link to comment Share on other sites More sharing options...
611 Posted September 2, 2014 Share Posted September 2, 2014 You should find you have the black door panel, then a white/clear big plastic washer (like in the picture) and then the clip would sit in front on the plastic washer (it stops the clip chewing up the door panel) So its a bit of a fiddle get the screw driver in behind the winder and before the flat plastic washer and with a bit of fiddling about you should be able to find the clip and prise it off. you should also find that the door panel will have a spring behind it pushing it out towards the winder so you might nee to hold this back to allow you to get the screw driver in behind the winder without scraping the panel. Once you have done one you will see how its all setup. I hope this makes it a bit more clear? Andy Quote Link to comment Share on other sites More sharing options...
Julian Posted September 2, 2014 Share Posted September 2, 2014 It's a lot easier if you have got three hands Quote Link to comment Share on other sites More sharing options...
Snowy Posted September 2, 2014 Share Posted September 2, 2014 Just buy one of these, no fiddling with screwdrivers again. You will find even cheaper ones than this if you look. http://m.ebay.co.uk/itm/331101954761?nav=SEARCH Quote Link to comment Share on other sites More sharing options...
611 Posted September 2, 2014 Share Posted September 2, 2014 Problem is,if i bought one of those i would put it in a safe place for when i needed it next, but would never be able to find the safe place i put it!! :-) Does look good though! Quote Link to comment Share on other sites More sharing options...
