Omega 2.5 Into Manta
john p
its probably been asked loads before but how hard is it to fit the 2.5 v6 into my 1.8gt hatch as im sick of it not starting/ticking over/driving.had it crypton tuned ran perfect tried it next day ran like shite again :angry:  :angry:  :angry:
just about to start this conversion with my cavalier,theres a guy on here with a v6 in his "A" he knows everything there is to know and has gave me some info already,he will reply on here.
so far i know we need,custom made sump,1.8 pick up pipe,xe engine mounts,move the rack down and notch the x member or put a bonnet bulge on it,and use the c25xe management etc...and mate it up to a getrag box or do an omege box conversion with involves cutting the tunnel i believe.
If it's any use I have a 1.8E from a mk2 Cav here, with everything to get it running. Use the head, camshaft and injection setup on your existing engine and you've got 115bhp and all the reliability of injection. It'll still need the wiring mods and fuel return line which andyc mentions above but it's an option.
2.0Ltr 8v injection from an old Cavalier etc. Will bolt staight up and being a 1.5 motronic it will onlly need four wires connection to get it running, once you have fitted a fuel return pipe
Andy
would that be from a mk2 or mk3 cav?
do you have a price ?
Edited by john p
Dont just fit the head, fit the whole engine. As from memory the 18E has a higher compression ratio than the 18S, so some of it's extra power/torque comes from this.
It is a higher compression engine, always assumed it was down to the design of the head but now I think about it the pistons probably have a lot to do with it! Still, just a case of swapping sump and engine mounts and re-using the Manta camshaft carrier to keep the original Manta dissy.
The 18E is by far the cheapest and quickest option. A V6 is quite a complex job and there are only a couple in the club, i'm planning a V6 but at the moment i'm collecting various bits and bods and trying to sort problems out before i get there .
Andy
If you're going to the trouble of changing the tank, adding a return and modifying for an electric pump just stick a valver in it.
My XE was on on standard injection. Returned great power and mpg. Was reliable. Easy to do. Parts are very easy to find.
There's a reason so many mantas are on xe power now. Once you change to a better engine in a manta your eyes are opened to how good the cars are.
well good news the car will be running again as is turned out that the vacuum advance unit is possibly the cause of the running probs so when I can get hold of one I will bung it on,also hopefully will have a lock up sorted soon so it will be coming off the road till next spring. will look for a redtop over the winter months and hopefully get it sorted.many thanks to all for your advice and offers of help
