Manta78 Posted December 29, 2014 Share Posted December 29, 2014 I Was Planning To Dip The Morris MInor But I Sent An EMail To SPL And They Said It Would Cost Over 2750 To Get Done Any Other Places That Do It? Quote Link to comment Share on other sites More sharing options...
bkautos Posted December 29, 2014 Share Posted December 29, 2014 theirs a place in manchester that charge me only £600 to get my old l200 dipped with zinc and galvanised finish Quote Link to comment Share on other sites More sharing options...
andyc Posted December 29, 2014 Share Posted December 29, 2014 About right, Manta cost about 3k. I did pick up some flyers atb the NEC for different companies When i get home i'll dig the details out for you Andy Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted December 29, 2014 Share Posted December 29, 2014 There has been a lot of bad press about dipping, with it weakening the steel over time, with trapped acids in joints etc. Quote Link to comment Share on other sites More sharing options...
andyc Posted December 29, 2014 Share Posted December 29, 2014 Here are the others i found http://www.prostrip.co.uk/ http://www.envirostripukltd.com/ I think in the early days there were problems with SPL as they in business to strip heavy equipment such as JCB diggers and the like. They didn't get into the car business until the V DUB found them and it got broadcast on TV and at this point they were still a bit green about doing car shells. These days they seem to got it sorted and the shells are washed alot better to get rid of all the acids in the metal and then it goes of to be E coated which will give you more or less a new shell finish. One thing to remember though is do all your metal work, even if that means getting the shell blasted first then have it dipped and e-coated. All my own projects will always be dipped as there will always be rot inside all the box section and you only need a spot of damp to start the rust off again Cheers Andy Quote Link to comment Share on other sites More sharing options...
Shug Posted December 29, 2014 Share Posted December 29, 2014 There has been a lot of bad press about dipping, with it weakening the steel over time, with trapped acids in joints etc. Worse than rust? Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted December 29, 2014 Share Posted December 29, 2014 Yea shug when your spending 3k to get rid of it! Quote Link to comment Share on other sites More sharing options...
Manta78 Posted December 30, 2014 Author Share Posted December 30, 2014 Thanks For The Help . Hearing That The Acid Could be Worse Than The Rust so unsure to do it now Quote Link to comment Share on other sites More sharing options...
upk Posted December 30, 2014 Share Posted December 30, 2014 Why not put the question to spl and see what they say? Quote Link to comment Share on other sites More sharing options...
Paul Barrett Posted December 30, 2014 Share Posted December 30, 2014 I've also spoken to a few guys that have had a poor service from spl on other forum. I have have to say I'd rather have a shell blasted by an experienced company that deal with automotive work mainly. Quote Link to comment Share on other sites More sharing options...
611 Posted December 30, 2014 Share Posted December 30, 2014 Didn't Derek on here have his whole shell blasted? might be worth seeing what his experience was like and views (https://www.facebook.com/opelmantagtr). i have the whole underside of mine done and it was amazing how clean they got it. if i had had the interior out i think i would have had the whole shell done. and they coated the whole thing in rust proofer. Apart from the dust that was left everywhere inside it was a great job. Not looked into dipping but if they dip it then wash it, i take it that they have to get it straight in and dried and then primer pretty quickly? Just some thoughts on things. Andy Quote Link to comment Share on other sites More sharing options...
andyc Posted December 30, 2014 Share Posted December 30, 2014 Its not painted but dipped in an anti-corrosion paint the has electrodes attached and the complete shell is submersed in the same way they do at the factory. This means all the inside and outside is coated and comes back to you as if it was a new shell. The shell we done about six years ago is showing no sign of any problems. Andy Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted January 4, 2015 Share Posted January 4, 2015 Place in Preston did my mates mk 2 escorts for 650 quid. That was stripped in an oven at a controlled temp and then dipped for a few days. They jetwash the shell after and spray with a zinc coating that lasts a few weeks. All the rally boys use them when rebuilding their cars allegedly Quote Link to comment Share on other sites More sharing options...
