Lsd Limited Slip Diff, 3:67
bkautos
  • 4 weeks later...
The Quaife Diffs are an unusual design, using ramps and rollers, take the driver away from them and they unlock, the Gripper diffs are a conventional design with clutch plates.
 If you got a diff sent to Oz then any good gearbox company should be able to install it, re-shim it to set the backlash on the gears etc.
 with the big increase in power your Manta is having a LSD would be almost essentail, you can spin the inside wheel on a standard GTE at roundabouts
With the big increase in power your Manta is having a LSD would be almost essentail, you can spin the inside wheel on a standard GTE at roundabouts
Yes I will have to do something as there is nothing more frustrating than spinning up the inside wheel at intersections and roundabouts!
  • 3 weeks later...
i have had it before when in the wet at a roundabout going onto a duel carrageway spinning one wheel and not noticing untill i went to overtake somone and the whole car started to wobble/twitch (hard to descibe) until i lifted off slightly. so i definatly wanted a lsd so at least you would know if the wheels are spining.
  • 2 months later...
