Phil N Posted August 23, 2015 Share Posted August 23, 2015 Hi, I have got hold of some englemann mirrors which I am painting white to match the car, I have some questions which google can't find the answer to so they are either obvious or can't be done- Firstly I have separated the mirror from the stalk by undoing the big nut inside the casing but is there a way of getting the metal balljoint thingy out of the stalk? I understand from a thread on here that they were originally mounted using self tappers, is this correct as the door skin is very thin..any advice or tips? Also is there any measurements to where they were originally mounted, if not can anyone suggest what they did? Thanks, Phil. Quote Link to comment Share on other sites More sharing options...
Phil N Posted August 23, 2015 Author Share Posted August 23, 2015 forget the answer to the first question as I just needed to man up and force it a bit! Quote Link to comment Share on other sites More sharing options...
robah Posted August 23, 2015 Share Posted August 23, 2015 Speak to Lepo5 (Paul) on here as he gave me the measurements for the mirrors, but I have misplaced the figures Quote Link to comment Share on other sites More sharing options...
stradacab Posted August 23, 2015 Share Posted August 23, 2015 I got them off hi too, think it might be in my J thread. take your point regarding the skin. I made two steel plates that were small enough to slip through the holes in the stregtnenerbrail at the top of the door and Sicaflexed them on to give extra rigidity and some more meat to screw into Quote Link to comment Share on other sites More sharing options...
H-400 Posted August 30, 2015 Share Posted August 30, 2015 Hope this will help you: From the top of the plastic feet to the fold on top of the door is 6 mm. Grtz, Herman. Quote Link to comment Share on other sites More sharing options...
Phil N Posted September 2, 2015 Author Share Posted September 2, 2015 Thanks to everyone who has replied, appreciate the help. Especially Paul who called me to discuss! Quote Link to comment Share on other sites More sharing options...
seangteowens Posted May 2, 2019 Share Posted May 2, 2019 On 30/08/2015 at 18:17, H-400 said: Hope this will help you: From the top of the plastic feet to the fold on top of the door is 6 mm. Grtz, Herman. Is the tape end at 29cm the centre of the mirror base plate? Quote Link to comment Share on other sites More sharing options...
H-400 Posted May 2, 2019 Share Posted May 2, 2019 Just took a better pic of this: Hope this can help you, Grts, Herman Quote Link to comment Share on other sites More sharing options...
