wayne ingham Posted January 29, 2016 Share Posted January 29, 2016 Need a oil pump plate ( the plate that gos on the bottom of the pump)The is a front cover on eBay but for £66.00 ????.So if you have one let me know .Snowy has sent me 2 but have not got them Link to comment Share on other sites More sharing options...
Paul Barrett Posted January 29, 2016 Share Posted January 29, 2016 I may have kne, will check over weekend 1 Link to comment Share on other sites More sharing options...
wayne ingham Posted January 31, 2016 Author Share Posted January 31, 2016 Hi Paul any luck finding the oil pump cover Link to comment Share on other sites More sharing options...
mantasrme Posted January 31, 2016 Share Posted January 31, 2016 Whats wrong with your original cover, is it broken or just worn with grooves in it? If its worn you can get it flat again by sticking wet and dry paper to a flat board, squirting wd40 or similar on and rubbing it back and forth for a while (long while if the scratches are deep) and you need to change the sheet now and then. Done it before a couple of times successfully on old covers. Link to comment Share on other sites More sharing options...
Julian Posted January 31, 2016 Share Posted January 31, 2016 Send me your address and I will post you one. Link to comment Share on other sites More sharing options...
wayne ingham Posted January 31, 2016 Author Share Posted January 31, 2016 Hi Julian My address is 5 BRINGE ROAD ROBY L36 4HX Let me know how to pay you Cheers Wayne Hi David The cover has a small crack in it so,can not be repaired. Once again the help l get form this club is well worth the price of being in the club, Link to comment Share on other sites More sharing options...
wayne ingham Posted February 2, 2016 Author Share Posted February 2, 2016 Have fitted the oil pump plate engine running fine (oil pressure took is time to get up) will have to check for leaks tomorrow. Thanks for all help gents 1 Link to comment Share on other sites More sharing options...
Julian Posted February 2, 2016 Share Posted February 2, 2016 (oil pressure took is time to get up) What sort of time, did you prime the pump,? or the time taken could have been because the pump wasn't primed? what I mean is are we talking a couple of minutes, or a long time? the plate I sent you has been in the cupboard for about five years, so did you check the relief valve, they tend to stick, especially when it has been left idle for a period of time. Link to comment Share on other sites More sharing options...
wayne ingham Posted February 3, 2016 Author Share Posted February 3, 2016 It was about 1 minute .when l fit engines in work they only take 15/20 seconds.But all is well in the world Link to comment Share on other sites More sharing options...
GTEPETE Posted February 20, 2016 Share Posted February 20, 2016 An old trick I used to do on Rover V8s is to fill the chamber with vaseline before bolting the plate up, helps with suction....to circulate the oil on start up..., Link to comment Share on other sites More sharing options...
