611 Posted August 1, 2016 Share Posted August 1, 2016 Ok, so i have a CIH 2.4 fitted with injection and i ordered the standard oil pressure switch (example pic attached) from Opel GT Source in the US and as the Frontera pressure switch fits into the side of the engine front cover the standard one won't fit as the trigger disc gets in the way. If the engine ran the basic Vauxhall injection setup it would be ok but the disc fits on the back of the pulley on my setup so it's in the way. Anyone know if something like this would work?? http://www.ebay.ie/itm/Oil-Pressure-Switch-for-VAUXHALL-Frontera-2-4-n-a-01-10-1998-Option-2-/311330874387?hash=item487cc42413:g:P2cAAOSwNSxVHXeJ Thanks Andy Quote Link to comment Share on other sites More sharing options...
andyc Posted August 7, 2016 Share Posted August 7, 2016 Andy, you need an extension that screws into the side cover then the OP switch screws into that and gives you the clearance for the trigger wheel. The extension isn't available from GM anymore but i'm sure you will find some in Europe, if I can find a pic of the last one I done i'll post it up Cheers Andy Quote Link to comment Share on other sites More sharing options...
andyc Posted August 7, 2016 Share Posted August 7, 2016 The only pics I can find. in the first one you can just make out the extension in the top of the pick If you can't find an extension then you might be able to get and engineering company to make one for you. Hope this helps Andy Quote Link to comment Share on other sites More sharing options...
611 Posted August 7, 2016 Author Share Posted August 7, 2016 4 hours ago, andyc said: The only pics I can find. in the first one you can just make out the extension in the top of the pick If you can't find an extension then you might be able to get and engineering company to make one for you. Hope this helps Andy Hey Andy, thanks for the info and the picture. Did the frontera have this on as standard? do you know if i can get a part number as might be easy to trace one in germany then. Could get one made, but not many engineering places near me that want to do one off's!! Thanks Andy Quote Link to comment Share on other sites More sharing options...
moodoo Posted August 8, 2016 Share Posted August 8, 2016 Andy, If you're stuck, I have a supplier I use in work for one-offs all the time. Mightn't be cheap,but if you sketch it up I can price it for you. Fin Quote Link to comment Share on other sites More sharing options...
andyc Posted August 8, 2016 Share Posted August 8, 2016 Hi Andy Yes it was standard on the Frontera but from memory its a bugger to find on the Fiche. Can't help with the number at the moment as I haven't got EPC on my laptop and i'm not looking to be back at work for a couple of months as I've just come out of hospital after a major opp. The extension is just a very long nut with an external thread at one end that screws into the timing cover and the other end is an internal thread for the switch to screw into, the OE parts still has the OP switch sitting very close to the trigger wheel. Cheers Andy Quote Link to comment Share on other sites More sharing options...
H-400 Posted August 8, 2016 Share Posted August 8, 2016 These are the partnumbers: (Opel and GM) 90322715 1252631 Quote Link to comment Share on other sites More sharing options...
611 Posted August 8, 2016 Author Share Posted August 8, 2016 6 hours ago, moodoo said: Andy, If you're stuck, I have a supplier I use in work for one-offs all the time. Mightn't be cheap,but if you sketch it up I can price it for you. Fin Thanks Fin. Must reply to you and box up those bits! Andy 3 hours ago, andyc said: Hi Andy Yes it was standard on the Frontera but from memory its a bugger to find on the Fiche. Can't help with the number at the moment as I haven't got EPC on my laptop and i'm not looking to be back at work for a couple of months as I've just come out of hospital after a major opp. The extension is just a very long nut with an external thread at one end that screws into the timing cover and the other end is an internal thread for the switch to screw into, the OE parts still has the OP switch sitting very close to the trigger wheel. Cheers Andy Hi Andy Thanks for the info and hope you are ok? Andy Quote Link to comment Share on other sites More sharing options...
611 Posted August 8, 2016 Author Share Posted August 8, 2016 2 hours ago, H-400 said: These are the partnumbers: (Opel and GM) 90322715 1252631 Hey, Thanks H-400, time for some googleing!! Andy Quote Link to comment Share on other sites More sharing options...
nickincrete Posted August 9, 2016 Share Posted August 9, 2016 i screwed mine into the block under the exhaust manifold with a 90 degree fitting found on 1.9 block. Quote Link to comment Share on other sites More sharing options...
611 Posted August 11, 2016 Author Share Posted August 11, 2016 On 8/9/2016 at 21:54, nickincrete said: i screwed mine into the block under the exhaust manifold with a 90 degree fitting found on 1.9 block. Hi Nick I use to have it like that on the old engine but no room with the manifold im running for the 2.4, it a bit tight down that side :-) Andy Quote Link to comment Share on other sites More sharing options...
