Mechanical fuel pump gaskets
IanMc
Whilst reviewing the fuel section of my Haynes manual, I noticed that it says that there is supposed to be a thick (asbestos?) gasket between the pump body and the block.
My car doesn’t have this and when I refitted the pump earlier I simply used a smear of instant gasket.
So now I have questions for the experts here:
- is the thick gasket essential?
- are there also paper gaskets either side of it?
- what thickness is the thick and paper gaskets?
- does the thick gasket mean that the pump shaft/spindle movement is restricted to a certain dimension?
- were the gaskets done away with on certain models/ages?
- what damage might occur if I take no further remedial action?
Thanks in advance everyone.
Panic over, there is actually no problem here at all.
I stripped the pump back off again this morning only to discover the thick spacer and two paper gaskets stock to the face of the block.
Made a couple of new gaskets and assembled everything again so I am officially back to 'factory spec' - that's about the only part of the car that is at the moment lol.
Moderators, you are free to delete this thread if you like.
Why?? Do you think that it's only you that do things like that?  I can remember replacing a rear road wheel, and thinking " these studs look a bit long" soon fixed it though, I pulled the wheel off and put the brake drum on!!!!  Who is perfect?  NO ONE. Any one else willing to admit anything?
Edited by Julian
