Cleaning Injectors
YOPANEWSHAM
32 minutes ago, YOPANEWSHAM said:
Tried to clean injectors on my GTE. Didn’t work so wondered who you use for cleaning and if anyone has substituted the injectors for another available type and had good results ?
There is a lot more to cleaning injectors than people think. Such as changing the filters etc.
So try this company
https://m.ebay.co.uk/itm/ULTRASONIC-FUEL-INJECTOR-CLEANING-SERVICE-CLEANER-/380072659398
Have the same opinion as Snowy:
sometimes you got to give some work out, I have no ultrasonic cleaner and they have the fitting filters and so on.
They clean the injectors under pressure in a ultrasonic bath while the injector is activated (powered) and give a test-result
before and after cleaning.
  • 2 months later...
Have you ever youtubed homemade ultra sonic cleaner! :D
....... have you ever youtubed how to clean petrol injectors, they can be reversed cleaned also, terminals switched to suck instead of blow....... eh!
Involves a syringe plunger, small household battery, check it out.
