peter evans Posted December 15, 2018 Share Posted December 15, 2018 What handbrake cable do I need for my manta b I’m using Astra mk4 calipers? do I use the Astra cable ? Anyone got pics showing any mods that need doing? Thanks guys peter Quote Link to comment Share on other sites More sharing options...
Mickfrad Posted December 15, 2018 Share Posted December 15, 2018 Retro power mention in this post about the mk4 Astra conversion using the Astra cable. Hope this helps, it's the same conversion I will be doing so if you can post some pictures when your done it would be much appreciated. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted December 15, 2018 Share Posted December 15, 2018 You can use manta cable, you extend the treaded bar on the handbrake assembly, thats if calibers are sitting at 9 o clock. I cut the threaded bar, used a hexagon spacer threaded on the inside, used locking nuts both sides, at least when you need a new cable, you will need a manta one! 😯 Quote Link to comment Share on other sites More sharing options...
peter evans Posted December 15, 2018 Author Share Posted December 15, 2018 Ok thanks for that just bought a Astra one also got a manta one in my lock up if I go that roure peter 👍 Quote Link to comment Share on other sites More sharing options...
mantasrme Posted December 16, 2018 Share Posted December 16, 2018 For the astra mk4 cable you need to lengthen the threaded rod for the handbrake yoke and add 2 stops for the outer cable under the car. Like this Then the caliper mounts behind the axle and cable approaches from underneath. For the manta handbrake cable the caliper needs to be mounted on top of the axle (which puts the bleed nipple at the wrong angle, but undo the caliper to bleed and then fit). I got a nylon piece made for the bracket to help the cable through a slight curve (must get some more made up). This is how i run them on my car as i do not want the cable under the axle. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted December 16, 2018 Share Posted December 16, 2018 Why do astra caliper need to be mounted at 12? Who knew, i didnt 😬 I use astra mk4 calipers at 9, manta cable, extended rod, but forced bleed, furthest first. Quote Link to comment Share on other sites More sharing options...
Atlantean Posted January 3, 2019 Share Posted January 3, 2019 On 16/12/2018 at 17:32, ®evo03 said: Why do astra caliper need to be mounted at 12? Who knew, i didnt 😬 I use astra mk4 calipers at 9, manta cable, extended rod, but forced bleed, furthest first. 8 I don't like the look of calipers mounted at 12 O'clock — 9 o'clock or 3 o'clock look fine, this is where most OE calipers are mounted I have a set of Astra G calipers here that I intend to use for a rear disc conversion but I hope to be able to mount them at Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 4, 2019 Share Posted January 4, 2019 On 16/12/2018 at 17:32, ®evo03 said: Why do astra caliper need to be mounted at 12? Who knew, i didnt 😬 I use astra mk4 calipers at 9, manta cable, extended rod, but forced bleed, furthest first. Do you have a pic of how the cable runs through the caliper brcket to the arm? I can't picture how it would without turning 90degress and rubbing Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 5, 2019 Share Posted January 5, 2019 My astra calipers are mounted at 9 o clock, using standard handbrake cable bracket, and manta handbrake cable, simple. Although the handbrake threaded bar is extended by about 6 inches. I use a hydro handbrake also, wont mot without a cable. Quote Link to comment Share on other sites More sharing options...
mantasrme Posted January 6, 2019 Share Posted January 6, 2019 So with the calipers mounted at 9 o'clock the cable needs to come in from the bottom of the astra bracket and pull the arm downwards. As its running horizontally back under the car how have you done the turn around the corner so the cable doesn't rub on the bracket? Quote Link to comment Share on other sites More sharing options...
®evo03 Posted January 6, 2019 Share Posted January 6, 2019 The normal wee cable holder with the wee plastic gromet sleeve is used, Although the handbrake end is probably less than 9 oclock when the calipers are at 9 oclock, cable clears everything, no mods bar the handbrake threaderbar length. Quote Link to comment Share on other sites More sharing options...
