284-285mm brake disks
Mantacol
wanted brake discs to match up with my calibre 4x4 callipers, I had set of 2wd sierra coswoth discs but I gave them to a friend to drill and lathe out the centres and it all went a bit wrong
so I am after a replacement set that are goo to go bolt on any one have any or know what may match without all the drilling ect .
if all else fails I will go back to std and send my old calliper's into bigg red for overall
thanks col
There's a guy on here called mantasrme (David) he sells the kit with Audi discs and calibra calipers which he has pre drilled. That's what I've got on mine. He might supply the discs separate?
Fittings no bother at all.
  • Thanks 1
