hoobby Posted July 6, 2019 Share Posted July 6, 2019 (edited) After fighting with the horn (single wire live) and it's unwillingness to obey the laws of physics finally worked out I cannot get a good earth from the steering wheel or the steering column nut or shaft. works fine if I give the button an earth from the door light switch.where would this assembly get it's earth. Edited July 6, 2019 by hoobby Single wire Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 7, 2019 Share Posted July 7, 2019 (edited) It gets its contact from the brass ring under the steering wheel onto a spring loaded pin under the steering wheel.this in turn gets its earth from the steering shaft itself. In theory it goes through the top bearing to the bearing carrier and via the nuts that hold it to the top of the column.check for loose. pretty sure it also can electrically travel through the lower u joint as I don’t think it’s got any nylon inserts ? Into the steering rack and through the crossmember . I’m trying to think if wether the actual crossmember is electrically insulated to the body though through its various rubber mountings .try it and see. maybee a linking strap across could be added. hope this helps Edited July 7, 2019 by cam.in.head 1 Quote Link to comment Share on other sites More sharing options...
Atlantean Posted July 7, 2019 Share Posted July 7, 2019 I’ve had similar problems with the horn on my Manta - I can’t figure it out at all! At one point I had 4 live wires going to them - simply seems to defy the laws of physics! Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 7, 2019 Author Share Posted July 7, 2019 contact pin and brass ring both covered in dirt and non electrical conductive grease.had a volt meter on this and definitely where it breaks down. Quote Link to comment Share on other sites More sharing options...
IanMc Posted July 7, 2019 Share Posted July 7, 2019 1 hour ago, hoobby said: contact pin and brass ring both covered in dirt and non electrical conductive grease.had a volt meter on this and definitely where it breaks down. So is it now working then Graeme? Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 7, 2019 Author Share Posted July 7, 2019 Hi ian....no it's not that photo is the live feed contact still chasing for an earth.the steering rack is earthed but this breaks down on the lower flexible joint and the upper uj.so going to put a loop of wire over both of these with a little slack should sort the problem. Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 7, 2019 Author Share Posted July 7, 2019 17 minutes ago, hoobby said: Hi ian....no it's not that photo is the live feed contact still chasing for an earth.the steering rack is earthed but this breaks down on the lower flexible joint and the upper uj.so going to put a loop of wire over both of these with a little slack should sort the problem. Yes it does . 2 Quote Link to comment Share on other sites More sharing options...
IanMc Posted July 7, 2019 Share Posted July 7, 2019 Can’t beat a bit of improvisation 👍 Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 7, 2019 Author Share Posted July 7, 2019 "make and mend" story of my life . Just on crock clips with a bit a wire at mo that will do for the mot then got to drop gearbox out to replace that tube will pull the rack out with the upper and lower joins.upper earth straps easy two pinch bolts but lower only has one pinch bolt and riveted together with a rubber cush drive bung thing will have to drill and tap something in. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted July 8, 2019 Share Posted July 8, 2019 Ah yes forgot about the lower flexi ! Doh so the only possible way it gets its earth is actually through the grease covered balls in the top bearing and through the bolts to the top of the column. How about some linking wires across each side of the uj clamp to clamp and the same at the rubber flexi too. That would help I would think ? Quote Link to comment Share on other sites More sharing options...
hoobby Posted July 17, 2019 Author Share Posted July 17, 2019 Well it's sorted now.the reason it wouldn't obey the laws of physics was I have a twin horn set-up 1 air horn the other a standard round one this was defective and causing a dead short just gave out a dink noise and sometimes works.still shows no earth on steering wheel on the avo but still it works all I can think is the voltage load overcomes this. Quote Link to comment Share on other sites More sharing options...
