Jessopia74 Posted December 3, 2020 Share Posted December 3, 2020 38 minutes ago, rutts said: Poly bush in Wrexham on packet is Red85 shore Mercedes 6 series 2AB Thanks, I will try to find on google later 👍 Quote Link to comment Share on other sites More sharing options...
novaman Posted January 6, 2021 Share Posted January 6, 2021 On 27/11/2020 at 18:38, rutts said: This setup is what is going on my ascona a. Using a Salisbury 4ha power loc differential 4.09-1 heavy but strong. Similar to group 4 chevette. Just had a total rebuild ready to fit. I'm loving this option, standard pick up points too, which is nice, have you fitted this yet & run it? Can I ask where you got the top arms bent? On 27/11/2020 at 18:38, rutts said: This setup is what is going on my ascona a. Using a Salisbury 4ha power loc differential 4.09-1 heavy but strong. Similar to group 4 chevette. Just had a total rebuild ready to fit. I'm loving this option, standard pick up points too, which is nice, have you fitted this yet & run it? Can I ask where you got the top arms bent? Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted January 9, 2021 Share Posted January 9, 2021 https://www.ebay.com.au/itm/Nolathane-Rear-Trailing-Arm-Lower-Arm-FOR-HOLDEN-COMMODORE-VK-46904/253894781871?fits=Model%3ACommodore&epid=20017015837&hash=item3b1d4eebaf:g:xaQAAOSw90le0uEY&frcectupt=true https://www.ebay.com.au/itm/HOLDEN-COMMODORE-VB-VK-LOWER-TRAILING-ARM-SUSPENSION-LEFT-RIGHT/173976859584?hash=item2881d433c0:g:dw0AAOSwGlJdOlN6 Quote Link to comment Share on other sites More sharing options...
rutts Posted January 10, 2021 Share Posted January 10, 2021 On 06/01/2021 at 16:49, novaman said: I'm loving this option, standard pick up points too, which is nice, have you fitted this yet & run it? Can I ask where you got the top arms bent? I'm loving this option, standard pick up points too, which is nice, have you fitted this yet & run it? Can I ask where you got the top arms bent? Not fitted yet almost ready for the change over. Top arms can be bent at quite a few places around UK. Nearest to myself is farnworth Manchester. 25mm cds tube Quote Link to comment Share on other sites More sharing options...
