Master cylinder
Kurtupsin75
Hi all need help on brake master cylinder purchased a jp. One but not correct also ate reservoir and warning level Cap both also wrong please point  me in right direction for right  ones thanks.
Ate 20s on master cylinder
For 20s cavalier coupe automatic
Edited by Kurtupsin75
there was one on ebay recently ,not sure if its still on ?
the ate one has the small flange whereas the later delco unit has a much bigger flange and obviously different servo.
i may have a used one if you want a rebuild but il see if i can find that new one on ebay for you
its still on ebay     type in
mbm709         and it should be there .hope that helps .
