12mm gates barricade
hoobby
I have got enough  gates barricade 8mm to change the fuel hoses but can't seem to find 12mm ID only 1/2" 12.7mm (too big ?) and don't want 25ft for £180  is there a supplier that I can get a short length from
Edited by hoobby
Too many oooooo's
On 19/03/2021 at 08:10, Sutty2006 said:
Give Autohose Milton a ring.
Found there site on eBay but don't supply gates and only have carb hose in 1/2" 12.7mm after a bit of digging around on ebay have found some 11.5mm r9 rated injection hose £21.95 for 1 meter so thanks for the help everyone now sorted :thumbup.
Just as a note suppliers of r9 hose choline 11.5mm and codan  12.7mm
Edited by hoobby
14 hours ago, mantasrme said:
Technically you don't need it to be injection grade for the 12mm pipe, carb pipe is fine as its only gravity feed to the pump there is no pressure inside it.
Funny just woke up with this realization this section would be under negative pressure so it would collapse rather than burst have ordered some and will change all of the fuel hoses next weekend.
