Rear axle disc conversion tuv/mot
mantageek88
Hi, a newbie question. I'm from Croatia so there aren't a lot of people modifying manta's and I was looking to upgrade my rear drums to discs. I couldn't find information here if the car will be able to pass the croatian version of MOT or TUV. Are there kits that come with a certificate? I see a lot of people doing this conversion, but I read on some forum that switch from drums to discs could be dangerous because of the brake force bias. Is this really a problem? Should i just leave it alone?😅 Thanks in advance!
To be completely honest, you don’t really get much gain from rear disk kits unless you modify EVERYTHING else.
I have Sierra Sapphire rear calipers using mk3 escort front disks and they pull the same force as the drums used to.
I’ve not heard of any certification for disk kits sold in the uk.
We don’t really know anything about the Croatian TUV test either
Croatian tuv is simillar to German. Basically if the the car with the modification can pass in Germany it can pass here. I won't be taking the car to the track or anything but I was looking to switch because of the looks and the simpler maintnance also if it makes the car perform a little better it sure won't hurt!
17 hours ago, ®evo03 said:
Valid point would be interesting to see the braking efficiency, but would have to be tested at optimum condition.  Both drum and brake being in top condition, takes both a while to get in, or burn of the newness.
I can't find that thread anymore, but I read somewhere on a forum, that you have to apply more force to drum brakes than disc brakes to achieve the same braking effect, so supposedly you're risking your rear tires locking up under braking. I don't know if this is true, so I wanted to check here first. Wouldn't want to risk my rear tires locking up. But I suppose since this swap is done a lot that it isn't unsafe😃
15 hours ago, Moonmonkey said:
Thanks for the suggestion. This is awesome, and the price is good too!
