Electronic ignition discussion
Metalbasher
Hello all, some opinion and recommendation welcomed regards electronic ignition conversion onto a 2.0 CIH. I fitted a Lucas system back in the late 80’s with no issue, but I’m nervous now about refitting as I build the car up again, noting the unit is now some 30 years old and stored in a shed for most of that time, I’m thinking the electronic bits may have deteriorated and would prove troublesome when setting up the engine. With that in mind, I’ve been looking at the Lumenition Optronic systems, anyone with experience of these on the Opel engine I’d welcome opinion, advice or recommended alternatives. Thanks
The distributor I have was fairly new at the point of taking the car off the road, it was also an Aldon Automotive performance unit so reluctant to change. Good point though, because I recall Aldon do their own electronic ignition which is worth looking into.
I would not put to much weight on that as a performance distributor (pun intended 😀)
But the GTE disi would be considered a performance advance curve anyway. Performance distributors should be tunes-d to your cars own vacuum characteristics anyway, so again I would not worry about that side of things.
‘Just a good solid electronic setup (points replacement or correct bosch distributor) will be superior to points.
3 minutes ago, Trooker said:
At €779 this isn’t cheap but interesting that this brand new CIH distributor is Bluetooth tuneable
https://www.123ignition.de/123-ignition-en/ignition-distributor-opel-rekord-manta-ascona-kadett-bluetooth.aspx
Better spending your money on Nodiz etc than that. Remove anything mechanical
That’s what I’d have thought, was a bit surprised that there’s a market for this & they need the original shaft/gear too.
I ran the Aldon setup ages ago on my 2.1 CIH and it was spot on, never any issues with it.
  • Like 4
if it were me i would just try what you already have . if it used to work then theres no reason why it wont work now.
then if it does actually prove faulty in time then sort it as req.
most of our cars are running the original system without issue and the newest  ones will be at least 35 years old !
  • Like 3
@cam.in.head
Just looking through older threads and noticed your advice about the ballast resistor wire and the coil. I ran the Lucas electronic ignition but never changed the resistance wire to normal 12v, never realised. What’s the downside to this and secondly, do I need 3ohm or 1.5 ohm coil?
Thanks in advance
most (if not all) electronic ignitions use a 12 v supply.
the original resistance wire idea was a good one as it gave a stronger spark whilst cranking but 12v electronic systems give a stronger spark anyway so dont benefit from a boost.
your other system may well have been perfectly happy with a lower supply voltage and if all the components including the engine were spot on then there probably never was any issues
the old non electronic coils would have a resistance approx 1.2-1.6 ohm and the electronic ign 12v ones 0.6-0.9 ohms. you may get slight differences due to different test meters !
thats using the standard oem units  (see spec in haynes book)
Thanks, that’s useful. The car ran ok but maybe could have run better if the system was set-up correctly, bit of an unknown I guess.
To summarise then, assuming I’m starting afresh with electronic ignition, I dispense with the OEM resistance wire and replace with 12v supply and fit a new coil which is also 12v. The system then becomes one with unballasted coil. Is that correct 🤨
